Question about Pugeot 2004 307 Triptonic engine
08.05.2020 19:09 # 1
Theschef
Greetings,
I bought a peugeot 307 1.6 xt last month. I am very happy with the vehicle, but the excessive noise from the engine makes me suspect. I put the expertise on the engine, they said normal. But when driving, an excessive noise is generated as if it was not taking over the engine. On the other hand, vibration occurs during the cycle transitions. I wonder why? how can i fix it?
08.05.2020 19:09 # 2
ondoz
If there is lpg, make lpg setting on the computer. There was a similar situation when I first bought my vehicle. I thought it was normal. The sound of the vehicle changed a lot when the LPG setting was made.
08.05.2020 19:09 # 3
Theschef
[QUOTE = ondoz] If lpg is available, set the lpg on the computer. There was a similar situation when I first bought my vehicle. I thought it was normal. The sound of the vehicle changed a lot when the LPG was adjusted .. [/ QUOTE]
After the car revolving hand is 35, 40, the vehicle shifts gear. This is why the vehicle is making excessive noise and chills. In addition, when the engine is running, the car is playing officially. I will take it to the peugeot authorized service tomorrow. I'm afraid of the gearbox. I hope it's not about the gearbox.
Theschef 2015-03-14 00:08:46
08.05.2020 19:09 # 4
ondoz
Could the sports mode remain active?
08.05.2020 19:09 # 5
xmen
there may be a problem in motor ears, chocks.
08.05.2020 19:09 # 6
Theschef
The sport mode is not active, the car is having problems at rpm. does not take over. Is there anyone with gearbox or knowledge? Do you have any information about the gearbox, thanks also?
08.05.2020 19:09 # 7
ondoz
When did the spark plugs change? It could also be spark plugs. A similar situation happened in my old vehicle. There was a problem with one of the spark plug wires in that car. So it was spark plug failure.
08.05.2020 19:09 # 8
Theschef
I went to the service today, the transmission is pert, I took the car to a special service, they dismantled the transmission, we sent it to Istanbul, zero transmission will be installed in the old container. Cost: transmission: 2500tl master price: 300 oil: 300
there is also more shipping fee. So the average cost me 3,000 TL.
08.05.2020 19:09 # 9
ondoz
[QUOTE = Theschef] I went to the service today, the transmission is pert, I took the car to a special service, they dismantled the transmission, we sent it to Istanbul, zero transmission will be installed in the old container. Cost: transmission: 2500tl master price: 300 oil: 300
Get well soon. Was there any problem when you first bought it? Did it depend on usage?
08.05.2020 19:09 # 10
talip206
I'm sorry to get past. I hope your master is good. Generally, the problem you mentioned could be solved by solenoid replacement. If it doesn't work, a revision is made. I do not know what processes you have undergone but I hope that the correct determination has been made. If the master who does not understand from work says immediately revision.
08.05.2020 19:09 # 11
Theschef
I showed it to 3 different masters. 2 special services and an authorized service connected to the computer and made a test drive themselves. As a result, all 3 agreed. Authorized service only asked me 5 thousand rubles for repair. Others have priced between 3500 and 2500 for laying zero material in the gearbox.
08.05.2020 19:09 # 12
Theschef
Do I have problems with the vehicle after the transmission I want to ask you? like performance. Does anyone know about these stages?
08.05.2020 19:09 # 13
Sertan
If you are a competent master, you won't have problems for years. However, if not, you can recover it by selling it. How many thousand of your vehicle? the Serta 2015-03-15 10:19:10
08.05.2020 19:09 # 14
Theschef
the skillful person really is. I researched a lot, I consulted my friends, I asked a technician friend at the Peugeot authorized service. I entrust it easily
