Question About 308
08.05.2020 17:48 # 1
altugg34
As you know, the 308s are 5 speeds in manual gear, and 6 speeds in automatic gears. Is the range of gears set as 6-speed in 5-speed manual gears? When traveling with 140, the tachometer at 5th gear will not be the same as at 6th gear. Will this not burn high speed in flat gear and burn more fuel on the intercity road? If we are going to buy 308, is it more reasonable to get automatic gears?
08.05.2020 17:48 # 2
Serkan
Hodja, first of all, you should know that the gear is not automatic, semi-automatic, if you do not have trouble in using manual gear, I do not recommend semi-automatic transmissions, they are not useful as fully automatic.
08.05.2020 17:48 # 3
altugg34
Hodja, will it not burn the car in 5th gear while driving with 140-150? It is interesting that 6 provinces are only semi-automatic.
08.05.2020 17:48 # 4
Serkan
I do not know about the gear ranges, I do not think that the fuel will make much difference, moreover, the semi-automatic difference is 5-6 thousand TL, it is really difficult to use, there is a lot of instability on the slopes, it is difficult to get used to it.
