quality oil |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:11 | # 1 |
| 08.05.2020 15:11 | # 2 |
dbmaster |
yes there are cold oil quality oil does not tear, and it is cool in the best way and also the quality oil does not decrease ... My vehicle string is definitely the only recommendation for you Castrol Edge 5 - 40 Turbo String; I have tried oils other than this oil until mobil 1 but only this oil did not decrease at 15.000 KM ...
| 08.05.2020 15:11 | # 3 |
[QUOTE = ask307] hi friends, does the quality engine oil really have any increase in the car compared to other oils? it's time to take care of my oil and I'm waiting for your help [/ QUOTE] In order to determine whether an oil is of good quality, it is necessary to look at the technical information written on the box. It is seen that these values are the same in Mobil 1, Castrol ... etc, which are generally known as brands. So technically there is no difference between them. However, the main difference is in the additives that companies research and find in their own R&D and add to the oil. They write what these additives are, but their content is a firm secret. The differences can be seen when the engine is urgent and examined after a long mileage, not changing a couple of oils. Again, the best is to try and try it yourself. |
| 08.05.2020 15:11 | # 4 |
I recommend mobile.
| 08.05.2020 15:11 | # 5 |
Hello my friend. In response to the question you asked, I want to tell you something that happened to me. I have work machines. It was 1 year ago. we changed the oil of the tracked bucket. Since it is a village location, there was no oil other than the oil office 15/40 in the place we worked. In the meantime, the oil office is not a domestic good anybody should think that I am smearing its domestic goods. I would gladly use it again. Anyway, we put the oil and the machine started to warn. The warning gives the engine faints and stops. his warning is not in my mind right now. But the new generation of construction machines are much smarter than cars;) Anyway, I called the authorized service immediately, I asked the warning code, when did you change my oil and what brand you put? I said p. Instead of pouring the oil, put a mobile castrol-style oil into it. as we said, we drained the oil and put on mobile 15/40 oil. there is no problem left. I think the brand of oil really has a lot of importance. |
| 08.05.2020 15:11 | # 6 |
[QUOTE = dbmaster] yes there are cold oil in the cold, the quality oil does not tear, and it does not decrease in the best way, also the quality oil does not decrease ... My vehicle string is definitely the only recommendation for you Castrol Edge 5 - 40 Turbo String; I have tried oils other than this oil until mobil 1 but only this oil did not decrease at 15.000 KM ... [/ QUOTE] it is normal for some oils to decrease. If you see it, for example, some of the oils such as shell mobile make a reduction in the presence of cleaning agents. the man who sells this is saying. Let her know that her subtraction is bad oil. In addition, diesel engines decrease an amount due to turbo. but that is not the case with the great proportions ... for example, I changed my oil with mobile 1 0-40. my friend said that he could diminish. we will try and see ... but I always recommend full synthetic oil. you can use this oil for longer km. I don't think it is meaningful to use semi-synthetics ... but it is also a question of price and therefore preference.
| 08.05.2020 15:11 | # 7 |
[QUOTE = cecoli] [QUOTE = dbmaster] yes there are cold and high quality oils do not tear, and the best way is that it does not decrease the quality oil ... My vehicle string is definitely my only recommendation for you Castrol Edge 5 - 40 Turbo String; I have tried oils other than this oil until mobil 1 but only this oil did not decrease at 15.000 KM ... [/ QUOTE] it is normal for some oils to decrease. If you see it, for example, some of the oils such as shell mobile make a reduction in the presence of cleaning agents. the man who sells this is saying. Let her know that her subtraction is bad oil. In addition, diesel engines decrease an amount due to turbo. but that is not the case with the great proportions ... for example, I changed my oil with mobile 1 0-40. my friend said that he could diminish. we will try and see ... but I always recommend full synthetic oil. you can use this oil for longer km. I don't think it is meaningful to use semi-synthetics ... but it is also a question of price and therefore preference. [/ QUOTE] This is the state of the rich man. Whether you're using 0-40: D |
| 08.05.2020 15:11 | # 8 |
[QUOTE = klemann] [QUOTE = cecoli] [QUOTE = dbmaster] yes there are cold and high quality oils do not tear, and my best string is definitely the only recommendation for you Castrol Edge 5 - 40 Turbo String; I have tried oils other than this oil until mobil 1 but only this oil did not decrease at 15.000 KM ... [/ QUOTE] it is normal for some oils to decrease. If you see it, for example, some of the oils such as shell mobile make a reduction in the presence of cleaning agents. the man who sells this is saying. Let her know that her subtraction is bad oil. In addition, diesel engines decrease an amount due to turbo. but that is not the case with the great proportions ... for example, I changed my oil with mobile 1 0-40. my friend said that he could diminish. we will try and see ... but I always recommend full synthetic oil. you can use this oil for longer km. I don't think it is meaningful to use semi-synthetics ... but it is also a question of price and therefore preference. [/ QUOTE] This is the state of the rich man. Whether you're using 0-40: D [/ QUOTE] wow wow wow wow so that's it :))))) I'm not rich enough to buy cheap I wonder if I was rich, would I get into this car :)) I would have a good 407 :)))) |
| 08.05.2020 15:11 | # 9 |
yaw I thought you were going to say a M3 or something
| 08.05.2020 15:11 | # 10 |
[QUOTE = klemann] yaw I thought you were going to say a M3 or something susale bi brother [/ QUOTE] m3 of our 306 biz is ours already :)) Meanwhile, I bought mobile 1 0-40 oil. 76 TL :))) normally 90-95 TL Don't ask me who I bought because that price is just private to me. The difference of being a tradesman :)) |
| 08.05.2020 15:11 | # 11 |
[QUOTE = cecoli] [QUOTE = klemann] yaw I thought you were going to call me a M3 or something susale bi brother [/ QUOTE] m3 of our 306 biz is ours already :)) Meanwhile, I bought mobile 1 0-40 oil. 76 TL :))) normally 90-95 TL Don't ask me who I bought because that price is just private to me. The difference of being a tradesman :)) [/ QUOTE] Hodja, the prices here are so dirty. The price of that oil was 65 Euros at the moment, and it was 75 Euros recently. I ordered online from Germany, it came to 30 Euros I ordered 5 boxes to extract the shipping money, mixed from it and 5W-30. Now I'm selling to 50 I was able to sell 1 more ![]() |
| 08.05.2020 15:11 | # 12 |
€ = 2.2 TL means 75 € here means 165 TL here ... good money masallah :)) |
| 08.05.2020 15:11 | # 13 |
[QUOTE = cecol of] € = 2.2 TL means 75 € here means 165 TL here ... good money masallah :)) [/ QUOTE]Yes, this is really bad. There is a small detail I would like to add about the oil. In some cases, fat reduction is normal, but in some cases there are serious problems in the future. So say: If we use a viscous oil than normal and use our vehicle with performance, the thinner oil starts to leak into the cylinders. This, unfortunately, causes the oil to burn, which starts to form carbon and adhere to the surface of the cylinder very little. This causes abrasion and over time causes loss of performance in the engine. |
| 08.05.2020 15:11 | # 14 |
[QUOTE = cecoli] [QUOTE = klemann] yaw I thought you were going to call me a M3 or something susale bi brother [/ QUOTE] m3 of our 306 biz is ours already :)) Meanwhile, I bought mobile 1 0-40 oil. 76 TL :))) normally 90-95 TL Don't ask me who I bought because that price is just private to me. The difference of being a tradesman :)) [/ QUOTE] Since my uncle is a wholesaler of oil, I buy it cheaper, gentleman, no air throwing for me as my ex-tradesman: D I also buy 7 tins in 1 tin of their gift;) |
| 08.05.2020 15:11 | # 15 |
I am buying the cheapest one, I have no claim or I am sorry.
| 08.05.2020 15:11 | # 16 |
masumserseri |
I have a question. I use castrol magnec 10w 40 to my vehicle. They say that this oil is compatible with both gasoline and diesel vehicles.
| 08.05.2020 15:11 | # 17 |
[QUOTE = innocent] I have a question. I use castrol magnec 10w 40 on my car. [/ QUOTE] It is semi-synthetical and it writes part over it synthetically. 10.000km is normal ... this ravage market price is around 55 TL. I would rather put a total quartz 9000 5-40 full synthetics in the same currency instead of that.
| 08.05.2020 15:11 | # 18 |
masumserseri |
Thank you cecolı.msj box emptied? I have been using castrol since the vehicle was taken as zero and I have been using it without hesitation since I used castrol since the old one. |
| 08.05.2020 15:11 | # 19 |
[QUOTE = innocent] thank you cecolı.msj box emptied? I have been using castrol since the vehicle was taken as zero and I have been using it without hesitation since I used castrol since the old one. [/ QUOTE] I was unloading ... If castrol is used continuously, you can use one of 2 oils, which is 5-40 fully synthetic, of castrol. in the cast of castrol 1.from edge 5-40 2.there are magnatec 5-40 Of course, changing the oil brand frequently is not good if you change it, but occasionally you will not change anything.
| 08.05.2020 15:11 | # 20 |
masumserseri |
Yes you are right when i have time to change the oil i am thinking of putting it on http://www.yedekparcaticaret.com/?urun-6520-castrol-edge-5w-40-t-dıesel-4-lt.html |
