Pusher problem
08.05.2020 17:16 # 1
pg307
With gasoline 307, I came from Ankara to Ankara without problems and very quickly. The car remained parked in front of the house for 3 days after arrival, while the weather was around -10. When I started it in the morning today, a loud noise began to emerge from the engine, similar to the sewing machine. I added antifreeze and oil, I waited for the engine to warm up. It is at 100,000 km and this is the first time that it does this problem. I called the Peugeot assistance, they told me to suspect the timing belt failure and remove it, they came with the tractor and took it to the service. Then they said not a timing, but a lifter problem. Valve tappets had to be replaced. They issued around 1500 lira bills. When I read the forums, I saw that there were friends who solved this problem with engine flush and engine oil change. What do you suggest? & Nbsp;
08.05.2020 17:16 # 2
xMEGANx
[QUOTE = pg307] With gasoline 307, I came from Ankara to Ankara smoothly and very quickly. The car remained parked in front of the house for 3 days after arrival, while the weather was around -10. When I started it in the morning today, a loud noise began to emerge from the engine, similar to the sewing machine. I added antifreeze and oil, I waited for the engine to warm up. It is at 100,000 km and this is the first time that it does this problem. I called the Peugeot assistance, they told me to suspect the timing belt failure and remove it, they came with the tractor and took it to the service. Then they said not a timing, but a lifter problem. Valve tappets had to be replaced. They issued around 1500 lira bills. When I read the forums, I saw that there were friends who solved this problem with engine flush and engine oil change. What do you suggest? & nbsp; [/ QUOTE]
Anyway, you will give 1500 TL. I'll say give it a try.
08.05.2020 17:16 # 3
msk_sansal
what is engine flush?
08.05.2020 17:16 # 4
_semihk_
"http://shop.wurth.com.tr/images/product/0893/0893-558-----motor-ic-tem.png"
if engine cleaning is required for the malfunction würth I say use it. a friend of mine had the same problem in his vehicle (war in me) said the hydraulic thrusters will change the service.
_semihk_ 2013-01-10 02:19:14
08.05.2020 17:16 # 5
msk_sansal
würth`s petrol injector cleaner also saved me from the old 206 m injector replacement. wurth candir. I will ask you how long it takes to clean the engine that & nbsp;
08.05.2020 17:16 # 6
_semihk_
in the engine ??? inside the hood?
08.05.2020 17:16 # 7
msk_sansal
in the engine
08.05.2020 17:16 # 8
_semihk_
it changes depending on which oil it takes from the oil when it changes to oil. But I examined it very much, brother. cleaning even lowers fuel. Ozmn I am a supporter to make 20-30 thousand.
08.05.2020 17:16 # 9
muratoner
& Nbsp; & nbsp; & nbsp; & nbsp; & nbsp; I do the injection cleaning work every 15000 maintenance. I saw and see very useful in the fuel and sound of my car.
08.05.2020 17:16 # 10
cey cey
08.05.2020 17:16 # 11
cey cey
I found this comment on a site, do you think there is a chance to be right
I do not recommend. A friend of mine who used 444 brand products used the same job. He had to make 1-2 liters of oil supplements a month. Finally, the engine was turned on. The rest is known. Many holes in the engine for years, etc. and engine cylinders get used to it. You clean them from the outside and these holes are opened. There is oil leakage from here and the oil decreases the car. I think there is no need. Use a good brand of oil instead of cleaning and replace it in time.
08.05.2020 17:16 # 12
SserkanT
I had the same problem in the morning (the car had been lying for two days) you described the sound coming out of the engine very well, I called a familiar master from the authorized service in the morning in the morning .. & nbsp; first suggested cleaning, let's take it tomorrow & nbsp;
08.05.2020 17:16 # 13
pg307
We spent a lot of time in the service today. First of all, oil and filter changes were made, the sound was slightly reduced. However, when the sound was not cut off completely, we started the disassembly process. The pushers have been removed one by one - there are 16 of them, one has to be removed and checked one by one to find out which one is broken. It was all clogged in my car, it was necessary to change the whole set. When we started, we said that we will change the timing set completely changed in 2007. As you know, this plastic piece has a 5-year or 80,000 km warranty. Mine did not fill the kilometer, but it had completed the year. The vehicle is still in service, I will buy it tomorrow. I do not know how much the bill will be released yet, but when I heard a figure of around 3000 TL, I got it out of the authorized service, took it to a familiar decent master.
08.05.2020 17:16 # 14
_semihk_
Is it not possible for those who are obstructed to be cleaned hod: S _semihk_ 2013-01-11 13:38:58
08.05.2020 17:16 # 15
msk_sansal
I had a drowning problem with us in the last service. I went to have the device connected today as if it is burning. What made the adjustment of the accelerator pedal. I said click while running, yes I said there seems to be a problem with the thrusters. There was also a click from the injectors. & Nbsp; they added a German additive for the injectors. & nbsp; I didn't know what to do for pusher & nbsp;
