Pulling problem
04.11.2020 16:49 # 1
Kolikli
First of all, Hi everyone, I have a 2012 model 1.6 gasoline LPG automatic vehicle, the car does not go on a flat road or uphill, the flat gasoline does not notice LPG, it does not exceed 160 km, I go up 30/40 la time when the counterparts on the ramps are 80. If I went to the master, it is okay, they say it's fine, they drive me crazy. I changed the coils, spark plugs and cables, again, the same fault lamp does not light, I connected it to the computer, it does not give an error code, I would like to listen to your feedback. Respects.
05.11.2020 08:45 # 2
And my alaeyküm selam teacher is a 1.6 vti engine performance engine. Even if the automatic loses about 20% of the power, it should not be that much. What is the transmission oil and pressure values.
06.11.2020 01:36 # 3
emirksk
Try cleaning the egr valve, it will probably work out. what brand of lpg kit? If lpg is not mounted on the vti engine like a man, it will be a very headache.
07.11.2020 19:38 # 4
347234
Where do you live? If you are on the Anatolian side of Istanbul, I can describe a master on the ÜMRANİYE side
10.11.2020 22:34 # 5
Kolikli
I had Prıns LPG installed at 50,000 km, gasoline, LPG grandfather, the same vehicle does not go, maybe I will clean the egr, there were some who said that it was exhaust catalyst. There is a situation like this, for example, I go up the ramp, I do full throttle, but it does not eat gas, it eats gas later, but the job is too late, especially if there are four people in the car, I do not hit the ramps at all. I live in Ankara. My problem is not that it is in LPG or gasoline.
11.11.2020 08:39 # 6
omerb
Greetings. Did you install Lpg? What was it like before LPG?
03.03.2021 11:49 # 7
Cenk88
hello, the same problems are also in my vehicle, have you been able to solve the problem?
07.03.2021 18:00 # 8
Mido5756
I have the same problem as well. Let me explain what happened to me
I left my vehicle to the body shop as a result of a small accident. We did not push it back and forth. He said, we put the oil, we put the water, we made it sound nice, there is no smoke etc. but losing speed in 5 gears, tofas ​​continues to slap on the straight road, my old engine was 150 thousand and it was magnificent. I wanted to sun while thinking about throwing a turbo, I had to spend money on the complete engine. By the way, when it came to the explosion of the engine, there was a crack in the cylinder and when the engine lay for a long time, the engine was filled with water from the crack, we could not notice that we were going to start it, we were not aware of the water or something under the vehicle, and we were a headless because the maintenance was always done on time and excessively and I never hurt, but the people at Peugeot service are misused of this engine. they say they love to use it.
Yes, if anyone can solve this traction problem, let us know. Have a nice day everyone.
09.03.2021 17:19 # 9
ozturksmh
Hello,
I had a similar problem with my 1.4 vti vehicle. I showed it to many masters and services, they could not find it. But the last time a master found it through trial and error, and the problem was solved. The "vti valve" found in these vehicles caused such problems. There are 2 vti valves. Whichever the problem is, the problem will most likely be solved if you change it.
