Pulling cables from 207 batteries
08.05.2020 21:23 # 1
scar1ove
I don't know if I did it before, maybe it was for the amp. I want to pull the cable from the positive of the battery into the vehicle without piercing a place. I wonder if I can pull the cable to the fuse box to the left of the steering wheel. I installed a key on the battery. I will hurt inside, until repair. I put the key on the battery, but I have to open the hood everywhere. I wonder where can I pull the cable scar1ov to 2019-12-15 19:18:40
08.05.2020 21:23 # 2
omerb
Hakan I don't know too. But I'm sure if there was such a large place that you had found so far. In general, do not connect the key to the battery cable and take it in. After all, electrical installation. You do your job well, but you do not know the vehicle before.
If you have a parking garage, etc. It happens in the next building. Park the vehicle there for a while. Keep looking at the problem. You are on my way
08.05.2020 21:23 # 3
scar1ove
I can look at it once a week because there is no closed garage, it is not looked at in detail in cold weather. so I'll try to handle it step by step. For now I thought it would be a temporary solution
08.05.2020 21:23 # 4
scar1ove
I pulled the cable out of the battery and the steering wheel goes up there. There is a cable path visible from the right behind the fuse box in the interior of the vehicle, that hole comes out under the brake fluid directly into the battery. the cable is pushed through the cables and removed from the front. If I need it, I will take a photo
