pug 307 sound from the front team (Squeak)
08.05.2020 13:56 # 1
Cnccoder
(2004 307 xt) When my car jerked on some roads, the squeaking from the front team on the bad roads gave the SOUND to the mechanic, it didn't solve the problem. I would be glad if there are ideas and opinions to solve the problem ...)
08.05.2020 13:56 # 2
So let me tell you, my brother, we do not recommend firing :)
Take the vehicle in the seat, look at the rot heads, do the playing, then look at the swings, have a skew and check the z-rods, you can understand them by hand and eyes, if you detect a problem, rot the press under the rod joint with the appropriate socket set and the rot is pressed out. Have you inserted the rear link of the epidemic, the swing is in your hand
In the meantime, the creak can come from anywhere, from the shock absorbers to the tie rod arm.
08.05.2020 13:56 # 3
Cnccoder
Thanks I will take this into account deran brother :) If you have any other suggestions, I would appreciate if you share with me ...
08.05.2020 13:56 # 4
If your vehicle has a sports spring, attach a hose to the springs.
If you don't have a sports bow, do the above practices.
I expect a lot of silence, and the character of 307 is the squeak on the bad road.
08.05.2020 13:56 # 5
Cnccoder
I have the original springs .. I searched on the internet without crackers this 307 :) I will be a man to hammer him on the right way:) ... thanks.
08.05.2020 13:56 # 6
Didn't you show the reform cozer when the problem went past
08.05.2020 13:56 # 7
Cnccoder
When I went to reform, I said this problem, but I did not have time, I did not have it, I had to come when other processes were over, we had a wedding. this sound was actually interrupted sometime later and started again. In reform, I went for the last starter malfunction, airbag error light, engine malfunction light, abs problem, my problem is solved. It is a nice thing to go without seeing any fault light on the peer of the vehicle :) .... before I told this service to the service, I searched for a great deal, I get a sound from every head. ..
08.05.2020 13:56 # 8
I guess whatever the problem is, but you do your own research, of course, but when I look at it, the net would be a creak not only in 307 but in all pugs.
08.05.2020 13:56 # 9
If we had a picture or video shot, we would have understood it more easily.
08.05.2020 13:56 # 10
Cnccoder
unfortunately I wasn't in the match because of my 56 impala problem: Cnccod is 2008-07-12 11:12:42
08.05.2020 13:56 # 11
Cnccoder
[QUOTE = 306TT] whatever the problem is, but you do your own research, of course, but when I look at it, there is a squeak not only in 307 but in all pugs [/ QUOTE]
Reform service Ali brother I have no doubts about this, the diagnoses he has made up to date have been correct, but I will go out of the city while my time is a little while visiting my holiday, but a nice but squeaking car finishes me :)
08.05.2020 13:56 # 12
lamazibici06
It is a good idea to look at the rod balance settings
08.05.2020 13:56 # 13
OguzhanKucuk61
Answer the topic in 2008 after 8 years ???
08.05.2020 13:56 # 14
ALLEX
[QUOTE = OguzhanKucuk61] Replying to the topic in 2008 after 8 years ??? [/ QUOTE]
I think this is the record
08.05.2020 13:56 # 15
OguzhanKucuk61
[QUOTE = ALLEX] [QUOTE = OguzhanKucuk61] To reply to the topic in 2008 after 8 years ??? [/ QUOTE]
I think this is the record [/ QUOTE]
Do not ask, brother :)
