pug 307 door speaker help
08.05.2020 18:28 # 1
muratk.balci
hello friends car 307 1.4hdi I have pioner deh 1500 ub tape in my car alone i don't like 307 speakers i just like how I can get the best voice by changing the door speakers thanks for your help.
08.05.2020 18:28 # 2
barishrocker
If it will not have an amp, hertz dcx165 can be bought .. If it will be an amplifier, I can make other suggestions .. but when it is done, get hertz dcx165 in front, and get hertz dcx130 in back.
08.05.2020 18:28 # 3
DreamTeather
I wish that what was done after the subjects were opened :) If we novices, we would have an idea!
Friends, I want to do something about sound. I do not want to pass 500-600 TL. I generally listen to acoustic, instrumental and folk music. I don't want to bass like that, I just need quality sound. Even if it is not bass. What can I do best. Does it work if I apply the " hertz dcx165 to the front and hertz dcx130 to the back " above . I know, I ask questions very often, but we are in the district, there is no one I will look at, consult. Thanks for your attention.
Finally, I was struck by an ad like this " http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-oto-ses-sistemleri-paket-sistem-jbl-komple-set-kampanyamiz-baslamis -completely-original-165783874 / detail "does this work or is it necessary?
dreamteath is 2014-05-24 23:07:00
08.05.2020 18:28 # 4
KIZILASLAN
[QUOTE = DreamTeather] If only the things that were done after the topics were opened :) If we were novices, we had an idea!
[/ QUOTE] If you don't want anything too exaggerated, if your aim is just listening to good quality music, buy a Pioneer tape or get a good quality sound from the original tape. I use it and I still use it because I like bass-weighted music, I added amps and subs, these speakers do your job more than you do.
08.05.2020 18:28 # 5
esppablo
I have a question for experienced friends,
I think the 2 hoporlor bursts on my side blew up because when I gave it there, it sounds very scratchy.
what would be the advice of the mentors I can change them?
I don't listen to loud music, just clean the sound. Is there a brand model that you can recommend the average pair to 100 liras?
08.05.2020 18:28 # 6
barishrocker
Available from jbl or pioneerin 35rms coaxial speakers.
08.05.2020 18:28 # 7
qqyyxx
Whatever you put in the front door of the 307s, you will not get any sound because there is no volume in those parts. the healthiest is to install an oval or round speaker on the rear pendulum.
08.05.2020 18:28 # 8
barishrocker
Exactly, it is an inconvenient door in terms of sound system .. It is difficult to get performance without touching the master hand..oval can be considered but I think it will not taste without sound from the front door ..
08.05.2020 18:28 # 9
BerkeKarayel
the front door hair should be cut, the pulley should be made, and the speakers should be mounted on the outer plate of the door, the curved hair, that is, the hair on the side of the seat.
08.05.2020 18:28 # 10
barishrocker
[QUOTE = BerkeKarayel] front door hair should be cut, the pulley should be made, and the speakers should be mounted on the outer hair of the door, the curved hair, that is, the hair in the seat side [/ QUOTE]
Berke knows these works well :) exactly like that.
08.05.2020 18:28 # 11
KIZILASLAN
just like there is a problem in the 307 doors, I put hertz mid, the sound was too cold, I took it out, I looked at it, the press blowers hit the plastic door face when it hit the sound, it sounds wheezing.
08.05.2020 18:28 # 12
qqyyxx
This time the magnet part will touch the door sheet when the screws are high. The best thing to do is to connect either the original or the 2-way component to the flat tape on the doors. for the amphitheater, oval in the back or just a woofer
08.05.2020 18:28 # 13
barishrocker
I will examine what is done in this link. There is a link to the sound system assembly, especially look there. It will give you information on everything;)
08.05.2020 18:28 # 14
DreamTeather
Does the following component work on the original tape? Does this remove the wattage event? They say the components give better sound instead of the plain speaker. What size should it be for the 307? 13 or 16?
http://www.hepsiburada.com/liste/jbl-cs-6c-165-cm-component-150watt-hoparlor/productdetails.aspx?productıd=otaytcs-6c&categoryıd=26090&sku=otaytcs-6c#yorum on
