pug'206 xs spring torsion adjustment
08.05.2020 15:03 # 1
d3Li
friends I will put the above rim down on my pug 206 xs vehicle.I will hit the ground in my car. I want the tires to not blow into the mudguards when 2-3 people sit on the back while lowering all of them. help: (tire size will be 205/45/16
the D3L 2011-01-18 20:48:27
08.05.2020 15:03 # 2
GokhaN
1 tooth and 5 cm eibach.
08.05.2020 15:03 # 3
d3Li
I thought eibach, but I went to the fk brand, and I got good comments from those who used the fats, but the fks are 4 cm as you say, there is a 5 eibach and 1 outside skirting base.
08.05.2020 15:03 # 4
alper
I think 1 tooth was falling 4cm. If there is wrong in the back torsion, correct it.
08.05.2020 15:03 # 5
d3Li
[QUOTE = d3Li] I thought the eibach, but I went to the fk brand, the prices are suitable and I got good comments from the users, but the fk is 4 cm as you say, 5 eibach and 1 outside do not have a kite base rubber. 205. [/ QUOTE]
08.05.2020 15:03 # 6
GokhaN
I use fk too. It's not a bad bow, but eibach is better. If you do not use a full turn, it will not rub. I am using 205 on 17 rims.
08.05.2020 15:03 # 7
GokhaN
[QUOTE = alper] I think 1 tooth was dropping 4cm. If there is a mistake in the back torsion, correct it [/ QUOTE]
exactly Göz Kırpma
08.05.2020 15:03 # 8
d3Li
[QUOTE = GökhaN] [QUOTE = d3Li] I thought the eibach, but I went to the fk brand, and I got good comments from the users who used the fats, but the fk 4 cm eibach as you say, and 1 do not have the need to knock outside the rubber sole 205. [/ QUOTE]
How many cm fk are you using? I found it to be 125 TL in terms of price. What are the situations when 4-5 people get in the vehicle?
08.05.2020 15:03 # 9
GokhaN
I use fk 4cm / 6cm = 5cm. I do not rub, I use cone with a damper. the back has never rubbed. If you go on, you can harden the rear shock absorbers, a little bit of an event. Göz Kırpma
08.05.2020 15:03 # 10
d3Li
I use [QUOTE = GökhaN] fk 4cm / 6cm = 5cm. I do not rub, I use cone with a damper. the back has never rubbed. If you go on, you can harden the rear shock absorbers, a little bit of an event. Göz Kırpma [/ QUOTE] fk 4 I said bnm fk 4-6 s level writing font in other places besides 5 cm I understood it as it says Gülme so many would you recommend eibach while using nie fk?
08.05.2020 15:03 # 11
GokhaN
I use [QUOTE = d3Li] [QUOTE = GökhaN] fk 4cm / 6cm = 5cm. I do not rub, I use cone with a damper. the back has never rubbed. If you go on, you can harden the rear shock absorbers, a little bit of an event. Göz Kırpma [/ QUOTE] fk 4 I said bnm fk 4-6 s level writing font in other places besides 5 cm I understood it as it says Gülme well, would you recommend eibach while using ni fk? [/ QUOTE]
I was using eibach on my old vehicle 106. It was not very soft and it fell well. fk it was very soft to me
08.05.2020 15:03 # 12
se®k@n
I think remove the side sills on the side .. So your car will be simpler and more beautiful after the rim and bow ..
08.05.2020 15:03 # 13
d3Li
[QUOTE = se®k @ n] I think remove the side sills as well .. So your car will be simpler and more beautiful after the rim and bow .. [/ QUOTE]
Actually, I want the original, but there is no return, I guess it was made with cutting. Is there any possibility of returning to the original?
08.05.2020 15:03 # 14
d3Li
up
08.05.2020 15:03 # 15
ali oncu
Press down 5cm, drop 1 tooth, then tire rim slide :))
08.05.2020 15:03 # 16
herry
Since our back is the subject, I am asking someone, maybe other people will benefit.
friends, what brand do you want to have a bow to coupe 206? Do you? Do not want to wear other bicycles when wearing this spring.
08.05.2020 15:03 # 17
d3Li
[QUOTE = ali pioneer] 5cm bass drop 1 tooth then tire rim engagement:)) [/ QUOTE]
thank you
Can I turn the rocker back to its original shape, I guess the above was done with cutting: Can I go back to the original?
08.05.2020 15:03 # 18
toprakk
If you drop 1 tooth, if you install 16 rims. If you sit 2 people in the back, that tire will surely rub on the dawl. but on stretch roads, on stretch roads at high speeds on long roads. it is not usually rubbing.
08.05.2020 15:03 # 19
As an eıbach pro-kit user, I definitely recommend buying eıbach
If you want to get cheap, my car is like a horse cart.
But if you want good quality in the pits like the original, your sound is strong, definitely eıbach ...
If you go cheap, you get fk tomorrow one day when you go to the pits on the bad road, you will be sorry but you will swear a lot from the fk brand :)
A recommendation as someone who uses it from me ...
In the back torsions, more than one tooth is rubbing.
