Puegeot 307 Fault Light and Antipollution Fault Hat
08.05.2020 20:04 # 1
peco307
My vehicle has not been fitted with a lpg (2005 extinguished my stove) in the 2005 model vehicle so far, this error exists in 90 percent lpg vehicles.
There aren't many good masters around here, but I brought it to the service, the spark plugs were old, the change has changed temporarily, but the vehicle is still falling from the cycle and does not eat gas. can friends living help?
08.05.2020 20:04 # 2
palet
The anti pollution fault error will light up when the fuel is not fully burned and dropped. this can be gasoline or LPG. However, if the coil also has a malfunction, it shows when you connect it to the computer. My advice; First of all, the throat butterfly should be cleaned. The timing setting should also be checked. Also, clutch pressure should be checked.
08.05.2020 20:04 # 3
Our brother made the necessary explanation. Clap If you already search the forum, you can find many related topics.
