Problems with 206 automatic car overheating
23.09.2022 00:02 # 1
umut1001
Hello friends. My 2008 model automatic Peugeot car started to give gas on its own when it got too hot in the summer in traffic, and it started to stop when I press the gas. There is no problem when the car is warm. Also, when it gets hot between Bursa and Istanbul in the summer, when I enter Istanbul traffic, it makes a thud from the back when I press the brake and stop. What do you think is the problem?
23.09.2022 17:44 # 2
talip206
Sir, if the oil cooler is faulty, it will do it. Or there are teflon bushings on the back of the gearbox, so it can do it. If there is a problem in the Teflon part on the back, it can be repaired by simply opening the back part without a complete revision. It's half the cost of the revision.
Otherwise, if you force the vehicle in this way, the pads inside the transmission will wear out and the worn parts will clog the transmission filter. In this case, it goes up to the revision.
25.09.2022 14:11 # 3
umut1001
Thank you Sir. I would like to have a complete overhaul because the car prices have gone up, the new one can't afford it. The car is 2008 model at 155 thousand km (it was at 125 thousand when I bought it about 6 years ago) How much does a complete overhaul cost? How much does a Teflon replacement cost?
28.09.2022 19:58 # 4
talip206
3-5 months ago, when the Revision started around 15000, it was around 5 pm that the back part was opened and the teflon bushings changed.
02.10.2022 21:24 # 5
umut1001
Unfortunately, every place can fit it now. It is necessary to investigate and find the one who makes it affordable. Of course, the one who does it properly. The market has been weird.
