Problems of the veteran
08.05.2020 20:48 # 1
capello
I have some problems in 407, which I have been riding since 2013. I am going to the eastern duty this year, I was not sure whether I will have the car built or replace it.
1- Every 2-3 months, the vehicle lights and stops all malfunction lamps, and generally works when it is turned off and on immediately.
2- Fuel consumption of the vehicle increased, approximately 6.5-7 lt mixed, is there any solution for this?
3- After I pass 130, I experience tremors.
4- Right side of the vehicle cools properly, but the left side does not work.
Do they have a solution, if any, how much can I explode and get efficiency?
What do you suggest.
08.05.2020 20:48 # 2
1-the problem is electrical, my teacher is likely to do it because the charging dynamo produces too much current
measure the vehicle battery and charger voltage values. If the average cost will change depending on the situation, the battery or something will have a path of 400-500 TL max. only if the dynamo repair is like 150-200 TL
2-The reason for the increase in fuel is that the maintenance time is approaching - the pressure pad is weakened - the condition of the injectors, etc. Depending on the situation, it is best to replace 4 of the injector repairs in the range of 500 - 1000 TL - with the flywheel and the flywheel.
3- If there is a tremor after 130 km speed, axle heads - tires, especially petlas-starmax, if they are common. front discs or hub. varies between 300-1000 TL depending on which part it is originated from.
4-If your vehicle is digital air conditioner, the steering flaps are peeling gears, there is a repair kit for my welded teacher 307, but I do not know for 407, but repair is possible. The price varies according to workmanship around 150-250 TL.
08.05.2020 20:48 # 3
capello
the battery was weakened, I just changed it and see if it will do it again
a rot balancer who had said that the right rear rim would make the curve from him.
I renewed the press brake, I did not handle the flywheel.
Unfortunately, I am unlucky when it comes to air conditioning.
08.05.2020 20:48 # 4
ggitaristt
1. As the problem is difficult to find, patience requires time and money. The most but the maximum fuse box or brain changes.
Others, I think, are easy to handle.
Do not believe anyone who says that every chest will fall.
I think a little more research ..
Also, if the car is clean, I think it is necessary to sell it .. What can you get better than 407 as a car?
08.05.2020 20:48 # 5
x571
[QUOTE = ggitaristt] 1. As the problem is difficult to find, patience requires time and money. Most but the maximum fuse box or brain changes ..
exactly. Now a vehicle you give 150 thousand is only in 407 hardware.
08.05.2020 20:48 # 6
capello
yes, I get a passat equivalent, but at least 100 thousand liras. I don't have that much money anyway.
So what is the solution of fuel increase. If we look at the injectors, will it be solved?
they do not understand the issue of ventilation, they are annoying, they always press the gas first.
