Problems in our vehicle Service Recommendation
08.05.2020 18:02 # 1
Ssedo
Good forums friends, we bought the second hand of the car. Anyway, it has been 3 months since we bought the car, we solved the minor problems ourselves. But there are quite a few big problems now I want to write them one by one.
- Oil is mixed in the water supplement tank of our vehicle, I think the gasket is gone or could there be another reason? or red antivirize, we had to add water, I wonder if it was such a strange mixture or oil was missing.
- There is a gas leak in our air conditioner
- water heater core of the fleeing car and there (I tried to comb out these issues, but the rest does not come off a bit was that I was stuck so I spent almost half a day here http://forum.peugeotturkey.com/forum_posts.asp?tıd=20250&kw=307+petek&title= coolant-water-vehicle-% DDine-szmas-problem will do this too)
- The car is singing on slopes
- Temperature rises very quickly
- The vehicle opens with the remote but does not lock, rarely crashes.
There are some other minor problems, friends, we've got the car a little cheaper, the meat of the cheap meat is black, the proverb is real :) the left mirror is broken: D we don't count it from the problem, among other problems
The car looks like the exterior, if we say change it, it will go cheap and we will not get it in the new car. The prices are obvious. We do not want to change such cars anyway. The comfort of our car is very good. So the friends I want to ask do you think we should take my car to my private service, or we don't want my authorized service to deal with the industry at all. Which service do you recommend in Bursa, the authorized person does not matter or not?
08.05.2020 18:02 # 2
radikalsovalye
greetings firstly
1. If your vehicle decreases oil, then understand that oil is mixed with water, and if the creamy texture in the form of mayonnaise is formed on the oil cap, the seal is gone.
2 they will go to a good air conditioner to press colored gas and find the leak easily
3. It is a job that requires a little bit of professionalism so it is best to show it to the mechanic
In the 4th slope, it may be kicking the butterfly throat. this topic has been opened in the forum (you can browse by me
The rapid rise of the 5th temperature is because when you remove the honeycomb, you do not complete the top of the water that is decreasing and not bleeding. take the air of the water in the forum
6 I have this problem, I couldn't even solve it :)
08.05.2020 18:02 # 3
samet206
First of all, there is no guarantee that they will fully solve your problems with the authorized services that deal with the problems you are talking about. Authorized service does not expect anything but ultimately, most of the employees working in private services come from people who have worked in such places before, but there is no workmanship in private services. You can say that the 30 TL piece is 100 TL even if the man does not have much workmanship.
I think the overheating event may be caused by leaks in your vehicle. You should go through the leaks first. they are made oil filter air filter they change. You change the heater core or have their gaskets checked. Why is there gas in the vehicle? If you spend an amount of 800-900 TL and you come across one that does good, there is nothing that will happen depending on the workmanship received by the price service.
08.05.2020 18:02 # 4
Ssedo
In the early days, it was not kicking anymore on the slopes, there is gas in the vehicle, we decided not to use it, and after 1-2 months, when we take the pensions, we are planning to put it into maintenance. We did the bleeding process, but since there is less water, it means that the air is running again. It is best to go to the private service. We have removed 1-2 thousand of them, as long as they keep the order :) thank you, my friends, if you can solve the door locking event in the service, etc. I will inform you, teacher.
08.05.2020 18:02 # 5
Ssedo
What is your name, where is my teacher
08.05.2020 18:02 # 6
Ssedo
Okay, teacher, I took a note, when we take care, I call and get detailed information from that friend.
08.05.2020 18:02 # 7
pierson
Is there a yalova peugeot service or a service you can recommend ...
