Problems After Battery Replacement
08.05.2020 21:16 # 1
Boz_Dem
Hello friends,
I couldn't find a post-incident solution that happened to me today. Maybe you can help me.
My car 2002 model 307 1.6 petrol automatic transmission XR
I forgot the quads of the car that I left in the park. When I arrived at the car, I realized that the battery was running out. There is no movement in the indicators. I think the battery is dead. By the way, it has been about 2 months since I bought the vehicle.
Anyway, we said to make a reinforcement from a friend's vehicle. I do not understand much about these things, I think the friend galler, who is a fuel maker, tied his polar heads first, a smoke came out of the batteries. We understood the situation and corrected the connection. The lights came on but they did not start.
We bought new batteries, we ran the car and everything was normal. Of course everything that looks is normal.
While I was on the way, I noticed that the screen shows P and not on automatic gear shifting. This is the first case.
I came home, parked, realized that the doors were not locked. The remote control was not working. I was closing the door manually. I cannot close the doors now. out of order. The driver's door is closing only at this time, the inner headlamp lamp does not stop, it feels as if the doors are open.
Not finished. The flashes of the flashers in the lock button light briefly lights up continuously. 4
Now what's wrong? I think the insurance problem is easy. But if we burned something else, wow.
There is no problem in gears and other instrument screens when the vehicle is running. Even the triptonic ble is working. In which gear I can not see pleasant.
If there are friends who have experienced and solved a similar problem, pls help.
I boz_de 2019-07-07 22:27:53
08.05.2020 21:16 # 2
GokhaN
Hi
battery amps correct? even if you can look at the battery and bsi
08.05.2020 21:16 # 3
talip206
Disconnect the battery terminal and wait a bit. Then plug it back in. I hope it was not good to have a short stream done, I hope it did not cause any problems.
08.05.2020 21:16 # 4
Boz_Dem
[QUOTE = talip206] Disconnect the battery terminal and wait a bit. Then plug it back in. I hope it was not good to have a short stream, I hope it did not cause any problems. [/ QUOTE]
I am aware that short circuiting has never been good, but I think there is protection for such situations. It seems like BSI would not work in other functions if it was damaged.
Gear changes, indicators, signals, differences etc. All components and electronic components work smoothly.
Today, I entrusted the car to the Maslak Ataturk auto industry Dilek oto Ismet master. Let's see if he can solve it.
If I understand the problem, I'll write it here.
When this intermediate battery changed, the car came to life, acceleration and gear changes were very good. In a way, this incident came to my work, but this door and gear indicator business got me bored.
08.05.2020 21:16 # 5
Boz_Dem
[QUOTE = gökhan] hi
A 60 amp battery was installed. I guess there is no problem in that. I pray that there is no BSI.
08.05.2020 21:16 # 6
Boz_Dem
Hello friends,
Unfortunately, the problem could not be solved. If they have a different idea, I am ready to listen. This Friday I will go long for the holiday. If you have an idea of how to lock these doors, it will help a lot. Frankly, I'm in a difficult situation.
08.05.2020 21:16 # 7
Boz_Dem
Hi guys,
The problem is that the car is involved in the brain. The central locking system is blocked.
It was necessary to install software again. Where can we do this work outside the Authorized service. As it is known, LPG does not receive service.
08.05.2020 21:16 # 8
ismailkaya
just find a service that looks at the peugeota connect it to the computer, I think the problem may not be the case, when locking the key manually, it only locks the door of the driver or does not lock any of them, locks all of them when the lock button is pressed from the inside or does not lock the vehicle when it passes 10 km speed during the first movement with your vehicle. Then insert the key into the door lock, turn it to the right, wait for 10 seconds and then try to lock it again from the control button. The key battery may also be exhausted.
