Problematic after the timing change. Refer.
08.05.2020 20:02 # 1
Eyup B.
Triger changed master, then I went a long way and parked in the evening.
I got up in the morning and it works like this. I tried 2 in the morning 2 is such. But it doesn't happen yet it just happens in the morning. He misses 1 time, then the 2nd anthem is slowly recovering.
what is the problem? I threw it from whatsapp to the master. "Diesel is making air," he said. so why would that happen after the timing? where can there be an error?
Note: filter maintenance was done 1 month ago.
the https://www.youtube.com/watch?v=1v0nyglhuq
[TUBE] 1v0nyglhuq the [/ TUBE]
Eyup B. 2016-11-18 14:27:38
08.05.2020 20:02 # 2
KILIC
Have you installed the diesel filter original. Sub-industry may be a problem.
08.05.2020 20:02 # 3
aykutcerit34
the Eyüp diesel filter may not be from the controllable hose.
08.05.2020 20:02 # 4
Eyup B.
The diesel filter may be the supplier industry. But the original said the man .... I asked him in a row. But it is confusing that it is after the timing. If it coincided wow :)
08.05.2020 20:02 # 5
ardinal
I looked at his videos, and I played a lot of knight. Seven of my life: D When was the diesel filter changed by the way? I am not a master but it is as if it is not a timing. I said to you, as I get rid of it, I get out of it: D
Edit: You wrote it okay it changed a month ago.
Ardinal 2016-11-18 15:42:50
08.05.2020 20:02 # 6
KILIC
The same situation happened to us 2 months ago, we bought the original diesel filter from the service, but we did not get it out there. The same situation happened, I went to the service, the diesel oil filter is defective, they changed it. They took their money in a new one because I did not get them to wear it :)
08.05.2020 20:02 # 7
KILIC
this beeps while running arad ailk sounds as if it is giving an error what does it say on the trip computer screen?
08.05.2020 20:02 # 8
mbsb44
My brother has not had a month yet. I had this problem. My car stopped after the first starter and it was getting on the 5th or 6th march. my troubles also came out of the diesel grip. the part that looks like a hand pump. the whole of the 358 pounds was bought from the original service. The master in the industry was originally not before he had fitted the sub-industry. Of course, industrialists took 1000 liras until this problem happened.
08.05.2020 20:02 # 9
Eyup B.
That beeping beep is because I run the door while the door is open.
- The two options are either a pump or a diesel filter, but the interesting thing is, why did the pump remove the pipes when the timing was changing? two irrelevant things. I took it off to put on the cover, then put it back on. Is there a problem here?
If you think this event is definitely from the air, you have lived.
So, is it harmful to run a contact like this? I plan to take it to the master tomorrow.
08.05.2020 20:02 # 10
Eyup B.
http://i.hizliresim.com/adpx4q.jpg
I took off this hose and put on his own hose, waited for 3 hours, worked, let's look smoothly.
08.05.2020 20:02 # 11
Eyup B.
A short diesel hose to the pump has been replaced and the problem has been resolved.
08.05.2020 20:02 # 12
KILIC
I'm glad the problem is resolved.
