Problem with the clutch
08.05.2020 19:45 # 1
Ronin271
Hello friends
I bought the 98 model xr vehicle just the first day, when I got on the road, it was okay, but when I wanted to shift 1 2 3 gear and went to 4 cu gear, I noticed that the clutch was softened and the 4th gear did not shift back, I tried to shift back again, then it did not happen, then I pulled to the ground and tried 1 2 3 4 5 reverse gears. It did not work, the clutch did not work, I did the hardness by pumping the clutch. Ronin271 2016-04-14 01:30:40
08.05.2020 19:45 # 2
ssakyel
First, the pressure pad and transmission oil should be checked. When was the last time the pressure pad changed?
08.05.2020 19:45 # 3
silverlion
My friend get past.
I had the same problem. I would fix the problem by replacing the clutch wire. I obtained the engine from the spare part with the chassis number, changed it myself and use it without any problems. Hope you deal with your problem.
08.05.2020 19:45 # 4
Ronin271
The pressure pad and the oil have just been changed, the repairman tested a friend for the control, he said from the clutch wire.
08.05.2020 19:45 # 5
Ronin271
Problem The clutch set leg will be broken and the compulsory clutch set will be replaced.
08.05.2020 19:45 # 6
silverlion
Anyway, there is worse. Get well again. I'm glad it's not a big problem.
