Problem with gear shifts
08.05.2020 16:49 # 1
FeverDog
Hello,
206 HDI Fever (2006 model 140.000km, diesel) my manual car is sometimes very hard and very loud when switching into reverse gear coming), as if I haven't fully pressed the clutch, but I do. and sometimes, when shifting into reverse gear, the gearshift comes to some extent; whereas it needs to go one more click to fully shift. I can only do this by hanging on the gearshift lever with 2 hands :) I also do this in shifting to other gears, but not as hard as in reverse gear. & Nbsp;
What could this be related to? I would be pleased if you answer, considering that I am a beginner; the problem may be with me too:) & nbsp;
Thank you. "Embarrassed"
08.05.2020 16:49 # 2
toga406
the pressure lining probably looks like looking at the km
08.05.2020 16:49 # 3
bjkamil
my 206 petrol also has the same problem. I think it's chronic. sometimes it does not fit properly when reversing. I'm wasted and trying again and again. "LOL"
08.05.2020 16:49 # 4
206206
my vehicle diesel & nbsp; When I shift into reverse gear most of the time, the gear doesn't shift. drain my foot & nbsp; and when I press it again & nbsp; going through the & nbsp;
08.05.2020 16:49 # 5
Cmoss06
In the 206's, the shift lever is working with the long iron lever that controls the gearbox. The gear shift lever is pushing on the gear and it moves the gears in the gearbox during the gear.When these steps occur, the gear lever makes a full sound, this situation must match the normal arm in the normal gear. Especially there are problems in 1st and reverse gear. The situation is normal. The situation will be the same if you change the pressure. :)
08.05.2020 16:49 # 6
Cmoss06
Of course, it is also necessary to check the cleavage separation unit.
08.05.2020 16:49 # 7
KenBlockJR
normal. Just sit right and throw back.
08.05.2020 16:49 # 8
esra_16
[QUOTE = 206206] my car is diesel & nbsp; When I shift into reverse gear most of the time, the gear doesn't shift. drain my foot & nbsp; and when I press it again & nbsp; going through the & nbsp; [/ QUOTE]
it means I have the same situation with this, the problem is not mine: =)
08.05.2020 16:49 # 9
FeverDog
Sometimes it feels like driving a truck :) As far as I understand, there is nothing to do except to get used to this situation. & Nbsp;
08.05.2020 16:49 # 10
toga406
Ah, if the gear of the piano is like a ford, it is both short and stylish. the gearbox is the same but the gear range is very bad
08.05.2020 16:49 # 11
FeverDog
Thank you guys, I guess for this problem there is not much I can do, and as far as I understand it is not vital. Now to discuss a new issue with a new title :)))
08.05.2020 16:49 # 12
toga406
if it doesn't leave, tampering continues
