Problem that cannot be solved automatically
08.05.2020 20:36 # 1
yusufmercan
Friends started to light the snow and sports mode lights in the 2000 model 1.6 xr variants, and we changed the solenoid valves on it, the oil changed the problem, it didn't fix the problem, then the plumbing system was changed, then the pipe called a pipe called the pipe and the part called the sensor did not change again. When you go for 5 km, is there any light coming on to protect yourself?
08.05.2020 20:36 # 2
So bro brother oil cooler checked? I looked at these oil pressure values, master looked at them, I followed the oil pressure when the oil was hot when the engine was cold, or change it according to the head did it change. master important to whom did you make the vehicle, a-city, they recommend the kamil master, I do not know exactly, but I guess it will come out when you call ankara kamil master. sonerkyl 2017-10-25 09:17:51
08.05.2020 20:36 # 3
kilic
hydraulic unit malfunction happened to me I know from there
08.05.2020 20:36 # 4
yusufmercan
The hydraulic block you mentioned
08.05.2020 20:36 # 5
yusufmercan
Soner brother connected to the computer gave the solenoid malfunction they changed the solenoid again when they failed.
08.05.2020 20:36 # 6
Well, my brother Yusuf, let us put us in the hands of good masters. Let's say I do not know exactly where I am, my brother, I did not have much work since I did not buy any automatic vehicles, but there were many people who recommended it to the forum. I found a special message to my brother if you wanted.
08.05.2020 20:36 # 7
yusufmercan
Thank you brother, let me show you in my day.
08.05.2020 20:36 # 8
runiy06
I have a full peugeot lover master in the capital auto industry in Ankara.
08.05.2020 20:37 # 9
yusufmercan
I had the complete transmission revision, by the way, as the friend of the hydraulic block is the source of the problem, thank you. the yusufmerc 2017-11-19 17:47:07
08.05.2020 20:37 # 10
talip206
[QUOTE = yusufmercan] I had the complete transmission revision, by the way, the source of the problem is hydraulic blocky, as the friend says, thank you, I'm riding smoothly without any trouble to everyone [/ QUOTE]
Where did you get it done? How much
08.05.2020 20:37 # 11
yusufmercan
There is vitas sanziman (good pine) in the bewildering. the yusufmerc 2017-11-20 10:40:51
