Problem of Not Working at Gasoline
08.05.2020 18:53 # 1
ihsanozlesmis
Hello friends.
My vehicle is 306 Manual Gear. the vehicle stops in gasoline, as soon as I take my foot out of the gas. There is no problem when it goes to the tube. It does not matter whether the engine is cold or hot. Also, it does not give any error when the computer is connected. Changed, there is no error, there is a trial and error method, repairers ... I am waiting for your answers.
08.05.2020 18:53 # 2
Mnc106
The same problem, I lived in 106, my friend, my injector was coming off, it was constantly stopping. A very annoying situation I hope it will be solved as soon as possible.
08.05.2020 18:53 # 3
_ali_
Could there be a leak in the gas? I do not know if such a thing can happen, but both petrol and gas are going to drown in the engine ...
08.05.2020 18:53 # 4
popeyes
[QUOTE = bestowed] Selam Aleyküm Friends.
my friend pray for me guys like me this form needs: D: D
the pressure of the gas tank should be 2.5 bar, I think that the pressure has fallen below 1.5 bar
When pumping gasoline, the pressure is insufficient. also because you drive your car under the quarter tank
I think it has clogged all the dirt injectors.
firstly clean the buoy of the gas tank or something
then fulle the tank and throw it away from the cleaner tablets will likely recover
you pray to me too
08.05.2020 18:53 # 5
ihsanozlesmis
He said it was time for the injector in my master, but at work ... he said from the oxygen sensor, we changed from the pump, we changed, the uncertainty started me
08.05.2020 18:53 # 6
ihsanozlesmis
[QUOTE = _ali_] Could there be a leak in the gas? I do not know if such a thing can happen, but both petrol and gas are going to drown in the engine ...
It may be, but I went to the scuba couple of times.
08.05.2020 18:53 # 7
popeyes
[QUOTE = bestowed] [QUOTE = _ali_] Could there be a leak in the gas? I do not know if such a thing can happen, but both petrol and gas are going to drown in the engine ...
gas is not a problem anyway, gasoline does not come to the injector or there is a problem that it is less.
08.05.2020 18:53 # 8
ihsanozlesmis
[QUOTE = popeyes] [QUOTE = bestows] Selam aleykum friends.
you pray to me too
The pressure was never measured, let me take your advice into consideration.
As you said, I usually use gasoline under the quarter tank.
My master (?) is suspicious of the injector.
I pray a thousand times in my vehicle Smile
