problem of not working
08.05.2020 19:44 # 1
muhoist
Good evening everyone, friends, I would like to share a problem with my car tonight. My car 2004 model 307 1.4 hdi when I press the ignition, the car sounds like an electric vehicle, the propeller turns like a sound, but the engine does not ignite it is not like an event when the battery runs out, it is quiet, it sounds like a wind noise, but the engine worked after trying 2 3 times the same problem occurred when I closed it. I have been researching for the last hour. Can the flywheel gear be broken? Are there any friends with such an experience?
08.05.2020 19:44 # 2
rzy.dnz
It is from the Mars engine, it will not bother, it will not be the case.
08.05.2020 19:44 # 3
muhoist
the starter is spinning, it sounds, but there is no sound from the engine about ignition.
08.05.2020 19:44 # 4
rzy.dnz
Mas is kidnapping, not firing
08.05.2020 19:44 # 5
muhoist
Thank you, another friend I found while I was researching wrote that "If the sound of turning to starter sounds and the car does not work, the starter automatic is not going to the flywheel".
08.05.2020 19:44 # 6
rzy.dnz
Get well soon
