Problem not working after stopping 306
08.05.2020 16:26 # 1
enilder
Good morning, brothers, I went out last night to go to a boat with my new battery, after a few weeks of my car without a battery, I bought a set of light bulbs in the parking lot of the boat. I went, I bought gasoline, but it was not like the gas was over, it was like he did not want to work. The engine did not move even though the starter was giggling. I pressed, worked, walked, went, stopped in front of the house while leaving his friend, stayed again, was not worked again, waited for 1 hour, we tried again, did not work again, last night I stayed last night in friends, I run this morning to see if I have fallen on the road, did anyone live this problem before or why who knows? I wrote a little long but thank you for giving advice to be understandable already
08.05.2020 16:26 # 2
sedataksu
As far as I understand, the problem started after the battery was replaced. The battery may be defective due to production error. If you want a look at it, the battery cables are fully and properly attached.
08.05.2020 16:26 # 3
enilder
Brother I suspect it too, the old battery must have a pole head and the other one is screwed. Since there is no screw in it, I clamped it on someone to tighten it well, but if there is a problem with the battery, does not it cause trouble when starting? & Nbsp;
08.05.2020 16:26 # 4
sedataksu
It is important how many amps the battery draws on the load. When the vehicle is running, it may crash when it gets on the load. It may not crash if it is not accidental.
08.05.2020 16:26 # 5
enilder
I thought in the first place, brother, but it seems like there is a situation in the gas system.
08.05.2020 16:26 # 6
enilder
Any other ideas?
