problem in the dial?
08.05.2020 16:11 # 1
zavur
Friends km up and counter counting problem is not on the sensor, the gear on the km gear will be removed, the gear will be removed, but this gear is not in the bag, do you know what this gear is and what its price is?
08.05.2020 16:11 # 2
Gokhan_S
I have the same problem in me. km.indicator does not work, needle does not play, my advice to you, take it to the master of the work, show it, find the source of the problem, not every electronics worker know.
08.05.2020 16:11 # 3
fexzi
What is your vehicle model? With the static problem, there may be a problem with the km wire, either electronically, either there is an error in the meter sensor or it stops because it has not made any progress with the km wire, it takes note of your current km and if it is from the wire, it moves automatically as much as it goes.
08.05.2020 16:11 # 4
zavur
my vehicle said that the gear of the km has to change, the 306 sensor has no problem. The worst thing is that the gearbox is not removed without dismantling diolar & nbsp;
08.05.2020 16:11 # 5
by_imp
friends, my vehicle has such a problem, alone my dial is up to 40 40 km, even if it is wrong, it kicks 1 km to 10 km "Sleepy"
08.05.2020 16:11 # 6
mehmet eren
I swear that there was a ford (dolmus) in our relative.
08.05.2020 16:11 # 7
fexzi
[QUOTE = poor] my vehicle said that the 306 sensor is okay, the km gear needs to change. [/ QUOTE]
is not like that, but there is a place on the transmission, it is definitely wrong with my information prediction.
08.05.2020 16:11 # 8
mon
The assembly, which consists of a pilastic gear and pinion, is pilastic, it will not wear much money over time but the gearbox will be completely disassembled because the mirror is attached to the blue. wherever you look, it costs 300 lira.
08.05.2020 16:11 # 9
I Love My Pug
Very bad situation, get well friends.
08.05.2020 16:11 # 10
zavur
I have tied my master here for 120 lira, and even the harder will be forced to lower the gearbox for 100 liras & nbsp; "Grin" (for the whole family and work for years our master master) I do not know what the piece is 50 lira they give me mesala & nbsp;
08.05.2020 16:11 # 11
zavur
In Çorum, Pejo's own service gave 250 TL of gearbox to download & nbsp;
08.05.2020 16:11 # 12
by_imp
Well, my repairman dial and km & nbsp; said there was a problem & nbsp; he said there was only one place that made him here, I couldn't stop by.
08.05.2020 16:11 # 13
zavur
I have reviewed a sensor for km sensor 306 part fiat 45 lira fiat & nbsp; If it is the sensor, the movement from the crank took the motion, the piece is called the gear, if the problem is in the sensor, there is not much workmanship. = "Embarrassed" title = "Embarrassed" />
08.05.2020 16:11 # 14
zavur
no rope satem & nbsp; & nbsp; our vehicles have a sensor that I know & nbsp;
08.05.2020 16:11 # 15
metin
If you specify the tool in the signature section, fill out your profile information completely. Go around like a ghost "
08.05.2020 16:11 # 16
zavur
"Laughter"
