Problem at 307 lpg
08.05.2020 16:42 # 1
arslanbey01
friends 2006 makeup van peugeot 307 1.4 90 hp car started to burn a lot now and i am thinking of having a tube installed. There are not many options in Erzurum, but KME & nbsp; There are brands like Lovato Zavoli Atiker and the most suitable is atiker & nbsp; I would appreciate if you answer my questions about these
1- Some lpg companies here say that 307s are not lpg compatible and they are constantly malfunctioning.
4- Previously 1.6 & nbsp; When I used the 2006 model 307, I had a problem, I had no problems.
08.05.2020 16:42 # 2
You will experience some loss of power. While the vehicle is loaded, there may be some trouble in the traction. Apart from that, I think it is not correct at 307 lpg.
08.05.2020 16:42 # 3
As you said in article 3, the brand is important, but the master who will connect that brand to your vehicle is at least as important as the brand. If I were at your place, I would entrust my vehicle to an experienced master who knows his job well.
08.05.2020 16:42 # 4
orhanax
For three years, I used the 2006 1.6 110hp vehicle with the Zavoli LPG system without losing power. I did not have any trouble other than the malfunctioning of the malfunction light. But as the koliva says, the master who wears the system is very important. An erroneous operation of the master can cause trouble in the future. You will not have trouble in a quality system that a good master will wear.
08.05.2020 16:42 # 5
okan4037
Let's see if there is a problem.
08.05.2020 16:42 # 6
ESES
Hello everybody. I want urgent help in a matter I have a very short time. & nbsp; everywhere I looked, the common result is the MASTER. & nbsp; Now I come to the topic, & nbsp; which brand lpg best suits my peugeot 206 cc 1.6 2002 model car? & Nbsp; I would like to say again that it is very urgent.
08.05.2020 16:42 # 7
efe1988
I have been using LPG for 2 years in my only brand vehicle, which guarantees not to turn on the malfunction lamp in the assembly of LPG in BRC and A2 engineering peugeot vehicles. 17:15:58
08.05.2020 16:42 # 8
metin
all aside, & nbsp;
the most important is the master. When it comes to the brand, the master wears the appropriate brand.
