Problem after LPG Filter and injector replacement
08.05.2020 19:32 # 1
riderzist
Hello friends
I have 2003 model 307 vehicle . I replaced lpg injectors and filters. The vehicle is starting late when it is `` engine warm ''. this is the interesting part. Let me stop for 15 20 minutes in one place and take the anthem in 4 5 seconds. No problem when I use it in gasoline. even if I don't forget, I put the car on gas and leave it. The lpg master says that the first run is not with lpg. ( lpg atiker )
Adapted from the computer, everything looked normal says the man. I used in ee gasoline 1 week was not abnormal in the car! abnormal when using lpg li.
this is the first problem
The second limit is that when the engine is cold at the first start in the morning, the vehicle gives a stop warning of 1 2 seconds with the abs light. I wait for the lights to go out when I turn on the ignition, meanwhile, when it is not waiting, our vehicles are not from it.
What is this problem, friends who had such an idea and solved it before?
The vehicle that has been running for 2 years without a click for 1 day has now bothered me. though there is nothing in the vehicle again, the problem seems to be caused by lpg.
I want to get it done without opening a bigger breakdown. the system is broken.
thanks in advance for your answers good forums
08.05.2020 19:32 # 2
xmen
Teacher, get past ... It seemed to me that there is a problem with the battery ...
08.05.2020 19:32 # 3
riderzist
Thank you very much. There was nothing until the filter changed and when it was used in gasoline, it works normally only after using it with lpg 15 and 20 minutes after it stops working hard. It takes 5 seconds. A very interesting problem
08.05.2020 19:32 # 4
Sir, this late working conversation is usually caused by the regulator and the small amount of gas leakage of gas cutters.
08.05.2020 19:32 # 5
dgngogo
if the smoke comes out from the exhaust and when the eoxose bursts on the way, it came to me from the regilator, my previous vehicle was hyundai eccent di mornings for 6 8 seconds, then it was taking it, it was not doing it, it was going to change the valve tires, the top cover will hurt with a software job: ))))
08.05.2020 19:32 # 6
_ali_
Gas cutter or LPG regulator is likely to be faulty.
08.05.2020 19:32 # 7
palet
I suggest you pay attention to the comment of our alpernbugra friend in the link.
http://forum.donanimhaber.com/m_78019384/tm.htm
08.05.2020 19:32 # 8
riderzist
Thanks for the answers, friends, I will evaluate them all. Thanks to friends who have other suggestions in advance.
When that problem was solved after lpg, I write here.
08.05.2020 19:32 # 9
ssakyel
Get past. I changed the injector in the past. I made two adjustments on it. The car still did not keep its old order.
08.05.2020 19:32 # 10
riderzist
I regretted that I would change it.
I exhaust manifold 3 cm capillary bi caught my eye I saw cracks in passing kaynattır today said egzozc oxygen repellent said go to master the monifol of welding electrodes bi place went recipes had 5 minutes to boiled drove did not take USTA DEBT WHAT I SAID man 40 TL said my brain jumped officially. What is 40 TL in 5 minutes, why are we brothers? I said 30 liras. It is a pity that people who work for the money all day, minimum wage, my diary is not much more than 40. I don't understand why these people became so stingy. > They do not work properly, when it comes to money, I do not know what to do with her price, services pattern is burning hands. we were afraid to take care.
08.05.2020 19:32 # 11
oguz41
You can also make gasoline pump, when you use LPG, you may be missing the gasoline, if you want, have a look under the seat ... May God help you.
