Problem after 206 valve adjustment
08.05.2020 18:50 # 1
Sercan Mungan
Good evening, valuable forum members, I made the valve adjustment due to the noise of the valves coming from the valves of my 1.4 petrol lpg vehicle at 43 thousand km.It was completed after the engine was removed and waited for up to 4 hours. I am playing in both gas and lpg at idling, is the valve setting not properly adjusted or is there another problem?
08.05.2020 18:50 # 2
Sercan Mungan
actual
08.05.2020 18:50 # 3
samet206
If the valve adjustment is not done properly, it usually breaks more quickly in LPG vehicles because it does not fit properly. Because the scheme should be done according to the scheme, look again. If there was no such situation before, it was probably wrong.
08.05.2020 18:50 # 4
Sercan Mungan
I could not fully pay attention to my fuel consumption, but I do not know the throat butterfly has been 4 thousand 5 thousand km.
08.05.2020 18:50 # 5
muro_60
You will have 20-40 valve settings.
08.05.2020 18:50 # 6
Sercan Mungan
I told the master who made it, but he said it should be a little looser because it is lpg, but I don't know how he made the adjustment.
08.05.2020 18:50 # 7
Sercan Mungan
I showed it to the authorized service yesterday, he said that the valve adjustment was not problematic in the vehicle, he even said that it was related to the gas adjustment, but he also made a test drive.
08.05.2020 18:50 # 8
sezar206
What was your complaint before adjusting? I think if I should have it too. My vehicle is very close right now, so when the engine is running, it runs silkintili, it works intermittently.
08.05.2020 18:50 # 9
Sercan Mungan
Lpg tuning master valve adjustment is broken, I made it according to my teacher, but I think it is more like a burning car.
08.05.2020 18:50 # 10
Ali1905
[QUOTE = 06MUNGAN47] I showed it to the authorized service yesterday, he said that the valve adjustment was not problematic in the vehicle, he even made a test drive.
How many milliseconds came out?
