PROBLEM 307 WAY COMPUTER
08.05.2020 20:41 # 1
Barbarosa
HELLO ABILIMS. 2004 MODEL PEUGEOT 307 THE ROAD COMPUTER OF MY VEHICLE HAS BEEN FROM THE UPPER SECTION, ONLY THE SUB-SECTION IS SEMI-SIDED. WHY HOW DO I FIX?
08.05.2020 20:41 # 2
Hello, welcome to us first. Capitalization is prohibited due to forum rules. When it comes to the problem, unfortunately, there is no chronic problem repair in the 307s, you will get a new trip computer.
08.05.2020 20:41 # 3
Barbarosa
I did not know. Excuse me. This problem occurred in my car after giving it to the hairdresser. It was working well before. I also researched this problem very often. The screen is silent, the problem is appearing as chronic.
08.05.2020 20:41 # 4
[QUOTE = Barbarosa] I did not know. Excuse me. This problem occurred after giving to the auto salon in my car. It was working well before. I also researched this problem very often. because it is visible
most likely they may have pressed the screen while shaking. you can try changing the bulb. the texts appear faint or not read at all. I have seen many people experiencing these problems, brother, you can be sure in the forum. Of course, first of all, change the bulbs, try it first, you will have to change it.
08.05.2020 20:41 # 5
ismailkaya
If your hand is inclined, disconnect the trip computer screen, check the disassembly is very simple, hold it with two hands, bend it back, that is, remove the cable from the socket towards the window, unscrew it.
08.05.2020 20:41 # 6
ggitaristt
In my opinion, as if you have nothing to lose, remove it without breaking it, plug it back with a medicine and check it .. check the screen glass connections etc ..
08.05.2020 20:41 # 7
[QUOTE = ggitaristt] I think there is nothing to lose, do not break without breaking and put it back with a whip .. check the screen glass connections etc ..
LOL sometimes it works.
sonerkyl 2017-12-12 09:43:33
08.05.2020 20:41 # 8
Barbarosa
Half of the screen is not even completely faint, only the bottom is left. As you said, I will look hungry or I will renew the bulbs so I will do it now. But I looked at the bulbs and all 3 were burning
08.05.2020 20:41 # 9
[QUOTE = Barbarosa] half of the screen is not even faint, just the bottom part left. OK, as you said, I will look hungry or I will make the bulbs renew so now. But I looked at the bulbs 3 of them were burning [/ QUOTE]
Unfortunately, there is no solution other than change.
08.05.2020 20:41 # 10
husem
I bought 206 ma and I'm looking forward to coming. I found you a few I threw in private
I huseyın 2017-12-12 11:19:46
08.05.2020 20:41 # 11
hozer33
I think you need to change the screen, I changed my light bulbs myself, I thought a few pixels were dead on the screen.
08.05.2020 20:41 # 12
Barbarosa
Ok thanks a lot
08.05.2020 20:41 # 13
husem
3 lines of screen I bought for 206 came right away.
08.05.2020 20:41 # 14
ersin61
Best wishes..
08.05.2020 20:41 # 15
husem
[QUOTE = ersin61] Good luck .. [/ QUOTE]
Thank you
08.05.2020 20:41 # 16
galesiz
hello how much did you get this screen
08.05.2020 20:41 # 17
good luck use it.
