PRND error
08.05.2020 21:10 # 1
emrermis
hello friends 407 2.0 executive premium auto lpg 173bin km it has been giving prnd malfunction in my car. There had been a coil failure before, then this failure came out, the coil was made but prnd does not go from the screen. There is no problem in gear shifts, there is no problem in tiptronic use, there is no mechanical problem, such as knock-in. In the industry, I connected to the computer, the transmission error does not appear. What could be the problem? In your opinion, a part called the electro valve has changed at 120 thousand km. Is there a master that you can recommend electronic or software related?
08.05.2020 21:10 # 2
talip206
When you say Prnd failure, can you open a little more. There may be a shift position switch malfunction.
08.05.2020 21:10 # 3
emrermis
exclamation mark on the screen says prnd never goes. We have also connected the fault locator to the problem, but as you said, there may be a position switch
08.05.2020 21:10 # 4
talip206
If you connect it to the original peugeot device, what exactly happens will appear. It is useful to check the sockets under the gear stick.
08.05.2020 21:10 # 5
Look exactly with the original software, it looks certain there are some malfunctions that you know to show on universal devices. There may be a problem with the position switch which our friend said.
