PRINTING PAD
08.05.2020 21:11 # 1
serkan066066
HELLO THERE,
THE PRINTING PAD OF MY VEHICLE WAS RUBBED. I CHANGED THE PRINTING PAD. AFTER THE CHANGE, THERE WAS AMAZING CRITERIA AND BOOKS IN GEAR TRANSITIONS. WHEN I REMOVE THROUGH GAS FROM THE GAS, THE SOUNDS ARE DIFFERENT IN THE VEHICLE. IS THERE LIVING THIS SITUATION? WHAT SHOULD I DO?
08.05.2020 21:11 # 2
the strange thing is that after the change, there were no such voices after it occurred. Finding a good peugeot master is the best. There may be problems in the transactions. engine mounting - chocks and clutch systems should be checked.
08.05.2020 21:11 # 3
serkan066066
yesterday I left the car to the master.I suspect it. they lowered the gearbox before changing the pressure and washed it with pressurized water. naturally, when the pressure was hit, water came to the gears in it.
08.05.2020 21:11 # 4
serkan066066
I received the vehicle. 600 TL more stuck. The gears are dispersed and collected, the bearing is changed, the socket is changed, the gearbox is welded for oil leakage and oil is added.
