printing is changing the pad
08.05.2020 15:21 # 1
ask307
Hi friends, I have bought the press brake bearings sponsor from the peugeot spare parts at affordable prices, somehow it will change tomorrow, do you think it will have a visible effect on the fuel going to the car.
08.05.2020 15:21 # 2
Muhammet CAKIR
It changes, of course, the traction of the vehicle varies.
08.05.2020 15:21 # 3
Faruk
How much did you get the pressure pad? I also changed the flywheel and clutch set completely.
08.05.2020 15:21 # 4
ask307
[QUOTE = Faruk] How much did you get the pressure pad? I also changed the new flywheel and clutch set. [/ QUOTE]
170 tl original printing lining bearing full set, I gave cargo at 10 tl came to 180 tl
08.05.2020 15:21 # 5
sercinho
you got the best price
08.05.2020 15:21 # 6
sercinho
[QUOTE = ask307] [QUOTE = Faruk] How much did you get the press pad? I just changed the volant and clutch set completely. [/ QUOTE]
170 tl original printing lining bearing full set, I gave cargo at 10 tl came to 180 tl [/ QUOTE]
Where will you make my change
08.05.2020 15:21 # 7
Haksen016
best wishes.
08.05.2020 15:21 # 8
Faruk
[QUOTE = sercinho] you have a nice price, good luck [/ QUOTE]
yes price is affordable
08.05.2020 15:21 # 9
ask307
Thank you guys, I met a friend who has worked at the Peugeot authorized service. He opened the shop, he will change the clutch + oil maintenance + brake maintenance + if he comes up with something in the undercarriage, he will change it to 150 TL.
08.05.2020 15:21 # 10
goktug
I think the price is appropriate if they will do all of them
08.05.2020 15:21 # 11
mdincer34
I just changed the press pad, there is an incredible difference, the clutch is softening, the gears are relieved, and the traction has increased, most importantly, there was tremor while getting up.
08.05.2020 15:21 # 12
Faruk
[QUOTE = mdincer34] I just changed the press pad, there is an incredible difference, the clutch is softening, the gears are relieved, and the traction has increased, the most important is the trembling while getting up, there is no trace left [/ QUOTE]
yes I agree, I just changed it, the car was like zero Göz Kırpma
08.05.2020 15:21 # 13
mdincer34
I think it would be better after a while until the clutch is seated.
