print pad
08.05.2020 18:12 # 1
jpm06
Friends bought the original print pad set from falcon peugeot. Since I was a foreigner where I was, I left the press pad to the master on advice. I bought it very well in the evening, the clutch was very soft, I didn't have any kidnapping or something. Only in this state I traveled only 1000 km and when I went to work the next morning, I saw that the tachometer jumped. I went directly to the master. I talked about my problem, the word the man said was not good, the pressure started, and the springs are bad. I said to the man that I bought the original and said that you are still corrupt, so that these events do not happen to me. Now if I hit this guy, would I be guilty. Angry jpm06 2014-01-11 11:40:52
08.05.2020 18:12 # 2
Serkan
The same happened to a friend named hypron (Can) from the forum, I think he was leaking oil from the transmission pad to the press pad.
08.05.2020 18:12 # 3
samet206
You picked up the piece, so it would mean it would always be easy to bring it to the piece itself or help solve the problem. If this side always comes with the piece itself, it would not be a word if it was the worst piece. I hope you will solve the problem ...
