print pad
08.05.2020 16:57 # 1
furkan111
Good evening everyone, friends
I changed my printing pad yesterday. But the drainage is grasping above .... I was not there when it was changing. I do not know because I have not changed.
& nbsp;
08.05.2020 16:57 # 2
Which brand did they put on the press pad? This is important. Did they show you the piece on another topic? He taught me my master. I take the car and stand on the steepest father ramp I can find. then I get up without hand brakes. If the car recovers itself immediately, it does not miss. If he misses the lining, he will not have a lifetime anymore.
08.05.2020 16:57 # 3
furkan111
they said they put me a volero, they even gave the price of 265 rubles ... I did not look at the old one. it is best to ask another master if they understand that they have not changed .... I have 1.6 xs, normally they should be very serial on departure, but it is not too serial
08.05.2020 16:57 # 4
It is bad that you do not have an important part change that you should stop at your car ... clutch is really an important issue. parts sub-industry appeared. pressure pad is a very important part. a fitted vehicle definitely grips below. The pedal starts to close and ends up grasping.
08.05.2020 16:57 # 5
furkan111
There is a gap on the pedal but the car knows how to skid straight on the road, I tried it ....
08.05.2020 16:57 # 6
[QUOTE = furkan111] there is a gap on the pedal, but the car knows how to skid on the straight road .... I tried it .... [/ QUOTE]
you will try on a steep ramp. high) it can be understood that he missed again.
08.05.2020 16:57 # 7
Serkan
Maybe my friend may have changed the hard pad, you may not have seen a difference since the old one is intact, the clutch's clutch above does not mean that the pressure pad is over, when I picked up the car it was at 72 thousand km, the clutch was very high up tomorrow, I was saying that my car is still at 111 thousand km. there is not the slightest kidnapping.
As I said before, did you miss it before changing it, if not, you changed it in vain.
08.05.2020 16:57 # 8
sahin-peugeot
[QUOTE = furkan111] they told me we put a volero, they even gave the price of 265 rubles ... I did not look at the old one. It is best to ask another master they probably understand that they have not changed or not .... I have 1.6 xs, normally they should be very serial on departure but as if they are very not serial [/ QUOTE]
& nbsp;
As the friend says, the brand is very important and you paid so much money. I wish you had the original
because it has a cheaper price of 215 TL the original, a good brand peugeot in valeo comes out most often in the original box, but as I always say, there is a quality difference, & nbsp; If you buy Valeo 50 TL less than the original & nbsp; okay, it seems like a bit of an exaggeration to give & nbsp; 50 TL more money & nbsp; & nbsp; & nbsp; & nbsp;
08.05.2020 16:57 # 9
furkan111
Do not ask, I ate a strange pile, I was not satisfied at all ... they made 20 30 more items in each piece when I did research and bidet workmanship ....
made list
& nbsp;
printing pad < / div>
right know what handle
shock absorber top chocks and balls
sanjiman bugs
gas pump .... the labor I gave them 1150 & nbsp ; & nbsp; My brother advised me, I was safe too, but he took the bill ...
