PRESSURE PROBLEM
08.05.2020 16:42 # 1
irfan3478
THE PRESS PROBLEM CANNOT EVERYWHERE I GO TO THE SERVICE.
08.05.2020 16:42 # 2
istanbullu_3886
I think your vehicle diesel pressure low diesel oil pump gives low pressure either the reil pipe or the reil customer may be malfunctioning.
08.05.2020 16:42 # 3
istanbullu_3886
if my turbo pressure is low or my reil pressure ??
08.05.2020 16:42 # 4
irfan3478
Ustadim vehicle 2.2 diesel I do not understand, I do not understand, the vehicle was connected to the computer, gave 2 errors, the pressure associated with the diesel pressure, we have to handle it first, I said, I have written it here. If I go in cycle, go to the long road, do not trouble, but if it hangs 2 thousand, if the engine stops, it will start for 15 minutes, but the vehicle will not run diesel if it rests for 15 minutes.
08.05.2020 16:42 # 5
irfan3478
The turbocharger of the vehicle was malfunctioning so we used it. When this problem came out, we made the turbo, master, but still the problem was not fixed.
08.05.2020 16:42 # 6
irfan3478
The car went to the pump, the problem was resolved. 4 injectors were revised, pressure sensor, pressure regulator pressure valve element valve seals inter color hose changed, pump adjustment was done. irfan3478 2012-04-25 12:44:31
08.05.2020 16:42 # 7
istanbullu_3886
Get well soon
08.05.2020 16:42 # 8
irfan3478
Thanks, my master, now there is a sound like a chain jump from the car engine.
08.05.2020 16:42 # 9
istanbullu_3886
Could it be clutch ball aceba
