pressure pad replacement cost research
08.05.2020 15:24 # 1
furkanbaki
friends, I felt a bit of a problem when switching to the gears today, the master looked, the printing is missing the pad, said hundai acl service, it is a district, there is no pejo, there is no other master I trust, the price is like 550 TL.
08.05.2020 15:24 # 2
xdesign
160 TL printing pad. 150 TL maximum workmanship. 300 TL. Fix is the price. But of course the service is different when it comes to work. You can also get it to industry. It doesn't require much mechanical attraction. The gearbox is lowered, the pressure set is removed and a new one is installed. Even if I am not a master, I can do it if necessary equipment.
08.05.2020 15:24 # 3
Burak07
I can not say anything as a price, but when you get it done, make sure you get the space set up. When I change it, my inexperience came when I changed it. There is a gap when changing gears.
08.05.2020 15:24 # 4
xdesign
The gear with the gap is always better xr07. We do not like it just to be cursed. But it actually increases the life of the prints. Because there is no constant gear contact. The light gap prevents that pressure and reduces friction.
08.05.2020 15:24 # 5
inceyasar
brother, I changed the printing pad to a set of 10, I had 10.000 maintenance, I gave 480, including labor, 300 lira parts in December (Pressure pad as set + oil + oil filter + diesel filter + air filter + transmission oil + 1 rear wiper)
08.05.2020 15:24 # 6
furkanbaki
I mean, they were flown at the price, I asked a particle, the orig pressure pad set said 180 TL
08.05.2020 15:24 # 7
frenzy
I bought TRW for 145 liras from the net. My brother also made the change (he is a mechanic too). I also washed his car in return Gülme By the way, if my friend Furkanbaki is like the price says, I think the price is very affordable ..
08.05.2020 15:24 # 8
sahin-peugeot
[QUOTE = furkanbaki] friends, I felt a little bit of trouble when switching to the gears today, the master looked, the print is missing the pad, said hundai acl service, this is the district, there is no pejo, also, there is no other master I trust, the price is like 550 TL. there must be [/ QUOTE]
What is a vehicle?
08.05.2020 15:24 # 9
parts prices are different if the vehicle is gasoline, different if diesel. I found the original of the diesel on the net for 230 tl. for gasoline people around 180tl. subject prices vary depending on engine volume
08.05.2020 15:24 # 10
furkanbaki
brother vehicle 2000 model 206xr 1,4 gasoline
08.05.2020 15:24 # 11
sahin-peugeot
[QUOTE = pugti] parts prices are different if the car is petrol, different if it is a diesel. I found the original of the diesel on the net for 230 tl. for gasoline people around 180tl. subject prices vary depending on engine volume
Diesel original 200 TL
08.05.2020 15:24 # 12
mdincer34
I gave 307 imin print linings and gearbox oil for 550 TL. I gave TL 150 more, so I said relax
08.05.2020 15:24 # 13
sahin-peugeot
petrol clutch set valeo 160 tl
08.05.2020 15:24 # 14
furkanbaki
Where can I get my brother from the net, I say I get it in the industry, I get 350, but I do not trust the experience of the master and the gap in that gear, but the service will take that gap.
08.05.2020 15:24 # 15
Now let me ask here, falcon master; how much is my clutch set
08.05.2020 15:24 # 16
sahin-peugeot
[QUOTE = furkanbaki] where can I get my brother from the net to buy it in the industry, I say it is 350, but I do not trust the experience of the master and the gap in that gear, but the service said it will take the gap [/ QUOTE]
If you need, I can give 350 TL workmanship only?
08.05.2020 15:24 # 17
sahin-peugeot
[QUOTE = badires] Now let me ask the falcon master; how much is my clutch set? [/ QUOTE]
I will give the original 220 TL for the campaign price
200 TL as Valeo
08.05.2020 15:24 # 18
furkanbaki
if my master is 206xr or if original is not valeo or not, what is the price?
08.05.2020 15:24 # 19
sahin-peugeot
[QUOTE = furkanbaki] if my master is 206xr or if the original is not valeo or what is the original what is the price of my master [/ QUOTE]
take out the original valeo, 160 TL as valeo
08.05.2020 15:24 # 20
furkanbaki
Is there anything else that my brother needs to change with this pressure pad set? For example, if we change the clutch rope, there is a light oil leak from the gearbox. Do you have a friend who knows what is being done?
Page : / 2
