Pressure pad help
17.08.2020 18:00 # 1
ahmetzeki
Hello, good evening, everyone, I have the 1999 1.4 xr 206, I have just changed the pressure lining of the vehicle, but it is still clutching above this normal, I got on 2005 honda, the last friend He clutches his foot from the pedal. -17 18:01:21
18.08.2020 10:44 # 2
x571
If it just changed, it won't be a problem. You can grasp from below with the pedal adjustment. I also know that if the clutch wire is connected a little longer, it will grasp above it. The same happened with my vehicle. The clutch that clutch at the bottom began to grip at the top after the change. I got used to it, it became 50 thousand km over time, no problem.
23.08.2020 17:15 # 3
ColoneL
I also have 2000 models of the same vehicle, I changed the brake lining 20,000 km ago. After the change he began to grasp above. The masters do not want to look at the Peugeot brand vehicle like a bogeyman in the city I live in, or do not want to overcome it, I did not care much about it because there was no problem of kidnapping, etc.
24.08.2020 08:54 # 4
It was my 206, my teacher, I did not get stuck much because there was no problem in fuel consumption and grip. time is already getting used to it, as you said.
15.09.2020 17:52 # 5
ahmetzeki
Thank you for the answers, guys, I wrote a little last but I'm sorry, I have no question if this is the case.
