Pressure pad and brake fluid
08.05.2020 19:11 # 1
vpro
Friends tried today whether the printing pad is finished but how accurate is it?
I put the gear in 3, I gave 2500 cycles, it looks like it moves with a half-circuit, but it hits the cyto as a full draw. How do you think?
2. On the very steep slope, the handbrake light did not come on and flash, what is the problem? Just my brake fluid?
08.05.2020 19:11 # 2
Efe-Pojo
You can tell if the clutch is missing by loading it on the throttle at low speed and high gear. If the vehicle is wasted and revs up, it is missing, if it is drowned and the web is accelerating slowly, there is no problem.
08.05.2020 19:11 # 3
vpro
Probably no problem I tried Thanks
together, I will add that hydraulics
08.05.2020 19:11 # 4
herry
You can tell if the [QUOTE = Efe-Pöjo] clutch is missing by loading it on the throttle at low speed in high gear. If the vehicle is wasted and revs up, it is missing, if it is drowned and the web is accelerating slowly, no problem. [/ QUOTE]
exactly Thumbs Up
08.05.2020 19:11 # 5
kopiiilcan
Good advice.
