pressing auto original paint into spray tube
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 15:20 # 1
mdincer34
friends I will paint the black laths of my 307 devil red tree myself, I researched for it and decided to paint it myself, but if I can spray the original paint, it will be easier to apply, so your advice is waiting.
08.05.2020 15:20 # 2
AUTO EFE
Peugeot & Citroen
Dismantled Spare Parts
0212 486 33 66
If You Want A Question To Efesi
08.05.2020 15:20 # 3
mdincer34
Nowadays, the intense Colonel Master :) joke, let me ask one side, he knows it at least
08.05.2020 15:20 # 4
It Will Help Help
08.05.2020 15:20 # 5
mdincer34
Let's meet together tomorrow, he knows, thanks to the places in ikitelli, Colonel, thank you for the information.
08.05.2020 15:20 # 6
mimitt
many painters in the industry do this application you want, but you should be very careful about color adhesion. Check the color tones in a small space or even on a different material if possible. Considering dust and similar elements, it will be in your interest to use a dust-free area with sufficient light sources.
08.05.2020 15:20 # 7
mdincer34
I can make the color hard with a little difference in other flat colors but I have to print the original paint on the tube
08.05.2020 15:20 # 8
mdincer34
[QUOTE = mimitt] This is the application you want in many painters in the industry, but you should be very careful about color adhesion. Check the color tones in a small area or even on a different material if possible before painting the bar completely. It will be in your interest to use a dust-free area with sufficient light sources considering the dust and similar elements.
Thank you for the answer, I learned the master primer job for plastic surfaces, I looked at the pantinar in plastic, 10 tl spray tube, then sand the surface with sandpaper, thin the sandpaper on it, then thin the paint, then I think it is like this :)
08.05.2020 15:20 # 9
toprakk
friend painting by yourself. My mower begins to peel off for 1 month. the first sandpaper of this is war. then war the primer then war the varnish on the war. war son war :))
08.05.2020 15:20 # 10
mdincer34
walla everybody says you can not do it anyway :) you can not do it in the installation go go give it to the floor they said they asked them to make a 150 tl installation cable to set up the amp :) if you do it yourself cost 29 tl :) plus when the process is finished, i am pleased to enjoy the fatigue so i always make myself i do the little things i put the pictures What should we do if it falls out after a month :)
08.05.2020 15:20 # 11
mimitt
Nothing does not give as much pleasure as human labor and sweat, as well as some research and access to the correct information, some things can be done even with the master. I went up and bought the products from sonax and made them, removed my rims and cleaned all of them, painted the calipers, cared for my leather upholstery, I asked 750 TL for these processes, I gave 175 TL to the products and completed the vehicle in two days with extra works. When the process was over, I had to come across it and probably watched it for an hour or so, then I immediately prepared and took a little tour of Ankara :) It was a little far from the subject but I couldn't hold myself sorry.
08.05.2020 15:20 # 12
Do it yourself. No matter how bad it is, you will still learn that this is the biggest gain I have for me.
It would be beneficial for everyone if you could take a photo or video while putting it here. Koliva 2011-04-27 07:53:07
08.05.2020 15:20 # 13
tigerland
I had it made the spray box did not match the color, but I painted the very close back belt and it was nice.
08.05.2020 15:20 # 14
If you go to a quality painter and give the paint code of the vehicle, they will stick to you full color and fill them into ready-made tubes. you also use it by spraying. There is a bitter adjustment in the mouth of those tubes. We built and used his car with the awl in the basement ...
08.05.2020 15:20 # 15
mdincer34
this is the priority I will add in the pictures I will make friends on the weekend
08.05.2020 15:20 # 16
mdincer34
friends today, I pressed the original color of the original devil red pajom in the ikitelli industry, it became a spray, the weather will get a little warm, I will complete the rest of the processors :)
08.05.2020 15:20 # 17
mdincer34
I forgot the price for 10 ml for 100 mlgrm free :)
08.05.2020 15:20 # 18
cerci07
If you paint well and take a picture at every stage while painting it, we will have information on the site.
Good luck with
08.05.2020 15:20 # 19
mdincer34
Don't worry, my friend, I will share the pictures and application stages of all materials by taking pictures.
08.05.2020 15:20 # 20
mdincer34
friends, the process is completed, I hope the pictures will work on the attached subject;
Page : / 2
