Press the Brake
08.05.2020 20:55 # 1
kayaca
I have 206 vehicles, when I press the brake or when the handbrake is released, there is such a rusty spring sound when it comes to a squeaking brake and it does it from behind.
08.05.2020 20:55 # 2
onlycihan
Generally, it is good to check torsions if squeaks come from behind.
08.05.2020 20:55 # 3
kayaca
[QUOTE = onlycihan] Generally it is good to check torsions if squeaks come from behind. [/ QUOTE]
Normally there is no problem when the vehicle starts, when there is a sound of 100m or so, the sound comes out and stops when the brakes are pulled.
08.05.2020 20:55 # 4
onlycihan
then the drums may have lost their function from the lining dust. The moving parts may not move easily. Have a check
08.05.2020 20:55 # 5
x571
[QUOTE = to rock] I have 206 vehicles, when I press the brake or when the handbrake is released, such a rusty spring sound comes, and it does this when it comes to a squeaking brake [/ QUOTE]
If you care for the rear drums, it will pass, it will be dust from time to time.
it is very simple even you can lift it with a jack. you unscrew the tire + you unscrew 2 screws. youtube there are videos.
x571 2018-06-11 17:32:43
08.05.2020 20:55 # 6
kayaca
[QUOTE = x571] [QUOTE = to the rock] I have 206 vehicles, when I press the brake or when the handbrake is lowered, such a rusty spring sound comes from the squeaking brake and it does this from behind [/ QUOTE]
Thank you, President I think that 90% pad is finished or I think it should be oiled.
08.05.2020 20:55 # 7
kayaca
The Rim Evil stands?
rock on 2018-06-11 22:19:42
08.05.2020 20:55 # 8
Kysr038
I got so used to the sounds in 206 that I don't wear them anymore.
The expertise of the industrialists in this regard is already excellent.
We are doing a test drive with the man, I say sound from behind.
He closes the window, brother does not come, look like a thousand.
Comedy film.
You go to the other and he immediately creates a solution
Brother, turn on the tape, you won't hear anything, the sound is in every car.
Either my masters do not want to spend very good money.
Or they don't understand.
I take great care of forum friends who go to the industry everyday and solve their problem.
08.05.2020 20:55 # 9
kayaca
[QUOTE = Kysr038]
Comedy film.
I think they do not understand octans in their masters.
08.05.2020 20:55 # 10
onlycihan
the rims look good but if you pull the whole car wide angle you can get a better idea
08.05.2020 20:55 # 11
KILIC
nothing more is understood from this photo, i think a photo showing the whole car would be better.
08.05.2020 20:55 # 12
kayaca
[QUOTE = onlycihan] wheels look nice but you can give a better idea if you pull wide vehicle like this [/ QUOTE]
08.05.2020 20:55 # 13
onlycihan
This size rim is good compared to the tire combination. The lip looks just like a frowned front view.
