Press Balata Flywheel Replacement Hk.
08.05.2020 19:34 # 1
cnrars
Gentlemen,
I have a 307 1.6 HDI 110 hp vehicle, yesterday Ankara Erkay has changed the pressure pad, flywheel, lower engine wedges, seals etc., kept 2200 pounds, meanwhile, there was a lot of oil leakage from the top cover, the car was shaking while getting up and the engine wobbles incredibly while stopping and starting and there were voices in the moth.
They said the reason was volan, and wedges etc. etc changed.
Now there is still shaking when stopping, but not as much, as there is shaking when running, but not much, but still I think too much.
The other issue is that I used to climb up to 2 with the slope 2.
I do not think it has anything to do with ESP .
Why could it be?
08.05.2020 19:34 # 2
IbRahiM_quRcaN
My brother is very old first. I made the same expenses last week. My car is 206 cc. There is a mechanism inside the gearbox called a group gear that may be broken. It may not have seen the Master.
08.05.2020 19:34 # 3
cnrars
Thank you for your answer, but the last 2 days ago it was based on 170-180s. It happened after these works
08.05.2020 19:34 # 4
samet206
Well, it may be anything but master, but I think the problem you are talking about is shaking while working and stopping. I think it should be reviewed by engine chocks. experienced masters should do this kind of maintenance.
08.05.2020 19:34 # 5
Faruk
The grip of the vehicle has been great, good luck.
I am going to Erkaya, my father has not been out of the house since 99.
I am very pleased with your skill and interest.
we use the same engine as you.
My vehicle at 240 thousand had low traction low speed, I asked the master, while opening and looking at the hood, we saw that the connection point of the turbo hose was broken, and they came out until we ordered.
As for the new one, it was as if I got on a zero car.
The slight leak in the hose caused a lot of loss in 1500 cycles.
I was using it for 1 year and saying that it goes like this when the km increases, but it has nothing to do.
My advice is to give you a good look at the turbo connections.
I suspect engine ears in engine stop and starting jerk.
I also had a lot of trouble, it was cut after a massive maintenance after the clearing, there was not even a slight jolt for 2 years (I changed what they changed, I do not know exactly because I have completely renewed the front team.
Replacing the flywheel stops vibration at take-off.
it is not a solution to jolts of other tremors
what's your km?
I think the turbo has a lot of oil leaks out there, says the service.
Meanwhile, my lion's early path appeared to cost again.
Since the cold has entered, there is a sound from the left.
I changed the shock absorbers in the spring, I'm afraid of the steering box: D
I wish the best.
08.05.2020 19:34 # 6
cnrars
Hello there,
My vehicle is 135 thousand, you know Adam, I have been going there for a long time, it helps with everything.
Yes, after the flywheel, the tremor in the departure has gone, the clutch is like cotton, but there is still swaying when stopping and operating, but not much, by the way, the engine chocks have changed, the upper and lower,
I don't know about the turbo, but he said we'll handle it at noon, probably something simple, I'm going to go at noon.
But especially after the 4th gear, 2000 cycles do not exceed, and if I root the gas, it does not exceed 100, of course, if it is not downhill, I have to shrink 4-3-2 depending on the situation and the road.
I hope it's a simple matter
cnrars 2015-12-28 10:49:42
08.05.2020 19:34 # 7
jackalizm58
My teacher has passed my printing pad, flywheel and wedges have changed, so we have done the same operation. If there is a fall in the traction, your vehicle is not spring-loaded, fixed flywheel is installed, so the traction drops significantly, but 2200 came to me like a very high figure. I gave 230 TL to the wedge ... but there is no such thing as not going to shoot 100 yesterday.
08.05.2020 19:34 # 8
cnrars
Hodja 500 pounds of pressure pad and flywheel what brand? not less than 1000 in many places?
Anyway, the man took care of it, while collecting the hose of the turbo, the battery was somewhere there, now it is like a monster.
08.05.2020 19:34 # 9
xmen
Exactly, I was wondering how they made 500 buckets, not less than 1000 buckets for the flywheel and press pad.
08.05.2020 19:34 # 10
jackalizm58
I can send it to anybody who wants to buy sachs brand friends Sivas from a friend who sells pejo piece in the industry 550 said, you give them give you 500 lira cash I bought I got out press pad + volant
08.05.2020 19:34 # 11
xmen
[QUOTE = jackalizm58] I can send it to anyone who wants sachs brand friends Sivas I bought it from a friend who sells pejo part in the industry 550 said, give them give you 500 pounds cash I bought I got out press pad + volant [/ QUOTE]
Okay, my teacher has a tremor in the vehicle, especially when it gets hot. First of all, let me show you what exactly is the problem and I will return to you.
08.05.2020 19:34 # 12
jackalizm58
[QUOTE = xmen] [QUOTE = jackalizm58] I can send it to anyone who wants sachs brand friends Sivas I bought it from a friend who sells pejo piece in the industry 550 said you give them give you 500 lira cash money I bought I got out printing pad + volant [/ QUOTE]
Okay, my teacher has a tremor in the vehicle, especially when it starts up.
Of course, I always help, if the departures are jerky, I will gladly take it from the pressure and flywheel.
08.05.2020 19:34 # 13
xmen
[QUOTE = jackalizm58] [QUOTE = xmen] [QUOTE = jackalizm58] I can send it to anyone who wants sachs brand friends from Sivas, I bought a friend who sells pejo piece 550 said, give them give you 500 lira cash I bought I got out press pad + volant [/ QUOTE ]
110 cm
08.05.2020 19:34 # 14
Faruk
[QUOTE = cnrars] Hi,
If Adam said he can handle it, it is easy.
it seems to me like a turbo hose drop in traction.
look at the chocks and ears in the tremor.
I hope there will be no costs.
I am waiting your good news.
08.05.2020 19:34 # 15
stain1903
The moon thing happened to me Edition Balata Volant changed + clutch fork broke, cost 700 TL, now clutch is like cotton. 307 hdi 2004
08.05.2020 19:34 # 16
cnrars
we have done the traction job now there are other things, the problem of traction has stuck the turbo hose while collecting the vehicle so the car is not going.
But when I stopped the car about a month ago, I took it because the head is stopping, the volant said it should change, the motor ears said, etc. were all changed, now the car is stopping in the same way, the car is stopping ashen + there is also a new version, stylish. Also, if you do stop for 10-20 minutes, get up and creak, while you get up, you get a squeak like a bed frame, what are these?
