preparation aid for examination.
08.05.2020 20:03 # 1
MadTurk_
Friends sa I hope I will be examined on December 17. I have parts other than the original in my vehicle. I need your ideas about whether these will cause me trouble or what and how I should do it.
Other than the original in my vehicle:
1) 215 * 45 * 17 rim tire (summer)
2) coilover in front (adjusted with one finger gap on tire)
3) double exhaust tip canceling the last muffler
4) angel eye headlight, led stop (all bulbs and leds light up smoothly)
5) Also, everyone knows that there is an antipollution fault error right now with the fault light (it goes out in the middle)
I would be glad if you help me what I need to do about them before the examination. Thanks in advance ...
08.05.2020 20:03 # 2
erendumlu
1) If the rim is not double application, no problem.
2) Originally he has to stay. It usually goes because they don't pay much attention
3) There is no problem unless you know someone who knows the job.
4) No problem
5) Fault light is not a problem. If you want it, you can remove the bulb from the dial and it will be over.
08.05.2020 20:03 # 3
maximusti
I passed through the 17 "rims,
my parking lamps were white led, they wrote a slight flaw.
as far as i know they are not original or muffler cancel exhaust,
If there is xenon headlight and american park, it does not pass.
08.05.2020 20:03 # 4
MadTurk_
let's add angel headlights have xenon. I guess it doesn't pass?
they say it is not certain when there is no silencer.
08.05.2020 20:03 # 5
erendumlu
Xenon headlight does not exceed. Xenon mast heavy defect without headlight wash
There will be no problem for the muffler subject unless there is a hair. As long as you get the stamp from the outside
08.05.2020 20:03 # 6
pepecura
IS YOUR VEHICLE DIESEL?
I passed without the last silencer. The xenon remains clear. led stop remains definitive
remains if the rims are 8 bolts
If any, American park fixed-burning windshield beacons remain severely defective. check the rear seat belts with certainty.
08.05.2020 20:03 # 7
MadTurk_
Does the LED stop?
said the car gasoline lpg silencer can not pass without an exhaust today
08.05.2020 20:03 # 8
dejawu1978
I think the coffee table for the Lpg tank came out and ask him this year.
08.05.2020 20:03 # 9
pepecura
good luck
sometimes even the heaviest flaws pass
08.05.2020 20:03 # 10
berkay847
American park, they do not have any trouble.
08.05.2020 20:03 # 11
Gokcesel
[QUOTE = MadTurk_] Friends hr I hope I will be examined on December 17. I have parts other than the original in my vehicle. I need your ideas about whether these will cause me trouble or what and how I should do it.
1) Seasonal winter, it is very difficult to pass with the summer tire. If you come to one of the bristles, be aware that you can ask for the rim in the original size.
2) You adjust the height and you will not have any trouble.
3) I do not think that the last muffler will pass as canceled. I'm not sure, but the exhaust tip won't bother.
4) Headlights pass, but not xenon. You need to replace the bulb. 5 months ago, 206 exams with led stop passed at once.
5) That mistake covers a lot of things. I hope it turns out when you get examined :)
08.05.2020 20:03 # 12
MadTurk_
I was already waiting for the examination to return to the winter tire. then before the examination, I have to:
1) winter tires will be fitted
2) the coil will be lifted up
3) bulb will be replaced instead of xenon
4) muffler will be installed
There is a bagel tube in LPG, they don't want anything.
08.05.2020 20:03 # 13
In addition, when my brother gets a bagel tube, they may have trouble with him. this mattress event came out
