Powertrain ...
08.05.2020 15:42 # 1
Powertrains are:
Clutch, gearbox, shaft, differential, axles, wheels.
The task of the differential is to increase the power, break the movement by 90 degrees and transmit it to the wheels with the help of axles, to ensure easy and comfortable cornering by turning the inner wheel less and turning the outer more.
Clutch (clutch) is the transmission organ that provides the opportunity to change gears by cutting the contact between the engine and the gearbox.
The axles transmit the motion of the differential to the wheels.
Gearbox adjusts the vehicle's speed and power.
If our foot rests on the clutch pedal while the vehicle is in motion, the clutch lining wears.
It is beneficial to press the clutch pedal to the end after giving some gas during the first start of the vehicle.
If the clutch lining get oiled the clutch slips. If wire of clutch break off vehicle does not gear.
When changing gears, press the clutch pedal.
If the vehicle does not engage when it is desired to engage reverse gear, the foot is removed from the clutch pedal and pressed again.
Gear oil is used as oil in the driveline.
If the sound comes from shifting, the clutch is fully pressed.
Sudden and firm posture can take off the clutch lining.
Attention is paid to oil and oil leakage while maintaining gearbox.
Source: auto market
08.05.2020 15:42 # 2
metin
Alkış
08.05.2020 15:42 # 3
[QUOTE = text] Alkış [/ QUOTE]
GKN 1 Thank you Metin im Sarma with olive oil
08.05.2020 15:42 # 4
Thanks for your effort. My colonel continues to investigate.
08.05.2020 15:42 # 5
respect for labor nice sharing thanks
08.05.2020 15:42 # 6
AlkışAlkışAlkış a huge + 999 to the effort you put into your mind that thinks this into your mind that uploads it here Thumbs Up come red Approve thank you.. you by_ 2011-06-27 12:47:09
