Powerbox with control for Diesel Peugeot
08.05.2020 14:10 # 1
rifatseker
Hello friends
Is there anyone who has experience that this type of product works? Someone who has done this and so on and used it and is satisfied? Can you share your ideas and thoughts?
Powerbox chip tuning with control for Diesel Peugeot
I http://www.sahibinden.com/dizel_peugeot_lar_icin_kumandali_powerbox_chip_tuning_yakit_ta-18wqqaxqq13478581wqqpxqqdisplayite
rifatsek is 2010-02-08 15:24:12
08.05.2020 14:10 # 2
Onur
would it work? sounds like a story to me but
08.05.2020 14:10 # 3
coyote26
friends, I do not think this product will work, I do not think it will be as effective as the power box cunku and the chip software in the brain, but chip tuning is working 1 year ago, I saw the benefit I did.
08.05.2020 14:10 # 4
they are deceiving empty mugs only
08.05.2020 14:10 # 5
Onur
these are all kinds of chip tuning stories
08.05.2020 14:10 # 6
berko
the other day we bought my friend cheaper than someone. For 206 hdi. It doesn't make 90 hp like the chip, but it does around 80 hp. The working principle is a very simple piece, not a story, but it is harmful in long-term and forced use. It lowers the signal to the injectors and the injectors spray more pressurized fuel to meet the gas response you give, thus increasing performance. We took the tuning in the middle setting and it will damage the injectors in the upper setting in long use. As soon as we took the car to Dynoya, it was very comfortable on the slopes, and its obvious performance increased. I have the 206 Hdi standard engine with obvious difference between them, but I say it is not as efficient as chip. If you already want high performance in the diesel and lift the engine, you will make a powerbox + chip, but considering the shortening of the engine life. berko 2010-02-09 00:20:02
08.05.2020 14:10 # 7
Onur
it is good but it takes the engine ...
08.05.2020 14:10 # 8
berko
Exactly, but if you see that it gives power and you don't come to the gas, there is no harm to the engine. power must be adjusted in this product too. All parts in the engine withstand 10% to 20% of power ex works without problems. The only job of this part is with the fuel injection system. If you do not push too hard, that is, if you set it to 80 hp, it says 86 hp in the list. these powerboxes are usually bought by multijet users, even if you read their comments online. a separate advantage of this is that you can disassemble it at any time. chip is the best system, but ultimately you are playing with the brain. berko 2010-02-09 00:49:48
08.05.2020 14:10 # 9
EminONAL
You don't run, Berk, you're going to get a chip :)
08.05.2020 14:10 # 10
rifatseker
Apparently we will wait for the warranty to expire. Gülme
08.05.2020 14:10 # 11
berko
[QUOTE = € m! N] you don't run, Berk you will get the chip in the end:) [/ QUOTE]
it looks like brother;)
08.05.2020 14:10 # 12
coyote26
friends, if you want to get information about chip tuning or information about the application, you can contact me privately .... I will be the Eskişehir dealer practitioner of EGE TURBO PERFORMANCE for the first time.
