Power Steering Fault Warning
08.05.2020 20:20 # 1
aslhnclslr
Hello .. I bought 207 HDI 1.4 about 3 months ago, my first car is very new. A few times when I put the key in the ignition, the steering lock was locked and I had to move the steering wheel roughly to start. After stopping the car, they said it would be because you moved the steering wheel, I didn't care ... Today, after starting the car, the power steering warning burned for a few seconds and went out. The cycle indicator did not work either. I stopped and pushed the car, started it again, the same warning came on and went out, but the speed indicator went up to 3 even though I did not exceed my speed indicator. I would be very glad if the problem shares its solution with me. Good evening...
08.05.2020 20:20 # 2
Halil5759
Have the battery and charger checked.
08.05.2020 20:20 # 3
Have a look at the status of the primary battery and charger as our friend said. If there is no problem, the steering pump should be checked, oxidation etc. can. worst case is that bsi and fuse box may have problems such problems are often unconscious engine washing - sound system and incorrectly connected xenon bulbs can also be a problem.
