porshce or rc rim
08.05.2020 21:07 # 1
kayaca
hi guys i'm thinking about buying a 17 inch porsche or rc rim porsche wheels 4x100 I have a 206-door 4-door vehicle. Does it stop too much?
08.05.2020 21:07 # 2
OguzhanKucuk61
If the vehicle is 1.4, there will be 17 Wheels. Even if it is 1.6 or 2.0, comfort decreases too much. 15-16 inches is ideal. It is better to look at the compatible rim without having to install the flange. The wheel bolt spacing is 4x108.
08.05.2020 21:07 # 3
kayaca
My coach 1.4 looked at these rc wheels offset 20 says the other offset 40 flange is mounted and the direct rim is designed out? I thought I was aware of my heavy future in that direction.
08.05.2020 21:07 # 4
GokhaN
I think it is unnecessary 15 or over 206
08.05.2020 21:07 # 5
kayaca
There are 15/55/195 tires on it, the vehicle feels like a plane, so I said let's download a little more :)
08.05.2020 21:07 # 6
kayaca
08.05.2020 21:07 # 7
maximusti
I've used 16 "porsche wheels for about 2 years ago,
the wheels are very heavy in kg, torsion, and the front set has been piled up,
and when someone sat on the back seat of 40 50 pounds started rubbing,
My advice is to use a 15 "original light rim.
08.05.2020 21:07 # 8
HakanYuksel
You can search Alufelgi BK-607. It is also referred to as the Citroen C4 rim. It was on the vehicle I bought and it has a nice view. I left the pictures below.
08.05.2020 21:07 # 9
OguzhanKucuk61
[QUOTE = rocks A] [/ QUOTE] I think the vehicle looks pretty good. No need for adventure :)
08.05.2020 21:07 # 10
crazysado
Does the tire size in your vehicle rub? I have 195 50 15 tires not flattened but there is no comfort
08.05.2020 21:07 # 11
kayaca
There is no problem in comfort, sports springs and rear torsions are low, so 2 people did not rub, but when they sit back, rubbing passes through the casing or something.
