poor performance
08.05.2020 20:56 # 1
Eray65
Friends still can't find a solution to the problem
When the vehicle travels on a 1.6 petrol lpg vehicle, it does not have a problem until 4 thousand cycles. No, it does not perform well after 4 thousand cycles. It does not exceed 130 u.
08.05.2020 20:56 # 2
GokhaN
4000 cycles of gasoline and LPG grandfather does not go to the same gasoline
How to clean the clutch, spark plug and general maintenance of the vehicle
08.05.2020 20:56 # 3
Eray65
same spark plug oil filters on gasoline and lpg just changed
08.05.2020 20:56 # 4
ismailkaya
If the vehicle has an oil leak on the side of the belt, the vehicle will not exceed 130, and if the clutch is finished, it will not come out. If the catalyst is obstructed, valve may require adjustment.
