Pollen Filter and Auto Glass Module
Homepage » PEUGEOT MODIFIED PLATFORM » 306
08.05.2020 19:57 # 1
Mr.Setoo
Hello everyone, first of all, when I went to change the oil of my car yesterday, I thought I would change the Triger and air oil and pollen filter while my ready hand was touched. When everything went very well, when it came to the pollen filter, I saw that there was no pollen filter in the vehicle and there was not even a place to wear it. Confused Vehicle 98 306 xr Sedan. According to the master, it seems between 93-98, but sometimes this situation can be encountered. Pollen filter appears when we look at it from the computer. Is this normal?
Another question is about the auto glass module. Does anyone have 306 tests or information about them? I am thinking of applying to my vehicle as 4 glass, but I have read comments on some forums that it may cause damage to fuses as a result of overloading the fuses.
08.05.2020 19:57 # 2
Hodja, don't worry, there is no pollen filter, unfortunately, I did not see it in your vehicles. in which it has come to turkey. I know that users who do this can put any pollen filter cross section instead of air conditioner air inlet. When it comes to the automatic glass module, the purpose of the fuse is to cut and protect the circuit in this type of electrical problems. The problem is that the modules will work for 3-5 seconds after the glass is closed, the only thing that will hurt is that it will break the glass lift engine and there will be no other problem to the vehicle.
08.05.2020 19:57 # 3
emresensoy307
The pollen filter was 99 xn gray, I don't know.
08.05.2020 19:57 # 4
Cyrus35
Even if you install the glass module, you shut the windows enthusiastically for 2 days, then you will not leave without closing it. And the electrical system on the vehicle of this age will get tired with the module, whether it be a glass lifting engine. Because when the module is installed, it lifts the glass to the end and forces it a bit, then cuts the electricity. I was glad that I used it for a long time, but again, the only harm left to you was the decision that I could not leave the vehicle without seeing that the windows were completely closed. use. When I locked the car, when my brother said that the glass remained open, the glass started to lift when he pushed his head in. I lifted the glass until it was hard to breathe. You need to think well if there is a need
