Polishing Plastic Parts on the Vehicle |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents | |
| 08.05.2020 17:46 | # 1 |
| 08.05.2020 17:46 | # 2 |
If anyone knows my friends, I would be happy if it helps. |
| 08.05.2020 17:46 | # 3 |
outlaw |
I usually use shoe sponge, it does not hurt and it is bright ...
| 08.05.2020 17:46 | # 4 |
I used to use it like that in the past, but now it has become dull, I don't know why there are stains. |
| 08.05.2020 17:46 | # 5 |
[QUOTE = samet206] I used to use it like that in the past, but now it has become dull. I don't know why there are stains. [/ QUOTE] I would say try the maguiars products. There are friends who use it around me. good products for both in-car and bodywork.
| 08.05.2020 17:46 | # 6 |
tlp |
There may also be protective products of Sonax Or you can use varnish for plastic |
| 08.05.2020 17:46 | # 7 |
[QUOTE = tlp] Sonax can also have protective products Or you can use varnish for plastic [/ QUOTE] When I say thank you varnish, is this paint permanent or something normal? In addition, I have this product from where I can get this product and I do not think it will be the only way to get it from the Internet, but there are more simple products in the markets. http://www.hepsiburada.com/liste/sonax-xtreme-nano-dis-plastik-lastik-koruyucu-parlatici-250-ml-/productdetails.aspx?productıd=otson210141&categoryıd=20035747 |
| 08.05.2020 17:46 | # 8 |
tlp |
We need to look at auto accessories Most of the construction markets have products that end, but I don't remember seeing that |
| 08.05.2020 17:46 | # 9 |
Alicilik |
If the places you are talking about are not painted and varnished, the dirt on them must be discarded to return to the old look. I would try rim cleaner carefully but you can use arabic soap instead. Then there will be a difference. If it is still matte, it has lost its characteristic and has bleached under the influence of the sun. You apply primer and paint, as a result, you will constantly waive the polishing process with sponge. |
| 08.05.2020 17:46 | # 10 |
I bought various materials from int to wash my car, I am not satisfied with what I use until now, or I am not sure that it is better than what I use until now, my aim is not to advertise here, everyone is trying to look at their own car, but there are products that I can recommend to other pug lovers as well. I recommend it because it is economical, there is a lot of variety and purposeful material. http://www.hepsiburada.com/liste/search.aspx?stext=e-max
| 08.05.2020 17:46 | # 11 |
Zagorka |
Hodja You Examine The Vehicle Part Of The Big Shopping Malls, I Guess You Will Find It There I Have It :)
| 08.05.2020 17:46 | # 12 |
I think to paint a permanent final solution. they all come and go. A bodybuilder looked great, painted his own 206 (piano black).
| 08.05.2020 17:46 | # 13 |
tlp |
The other day I painted with normal spray paint, lasting and definitive solution
| 08.05.2020 17:46 | # 14 |
I am so careful with this rim cleaner, because it will damage the bodywork, it will look at the medicine, then whatever the result will be and then polish it with a nice plastic polisher. depending on the appearance of my car, there is no modification other than the original steel, no matter if I do piano black by grasping it, it should be completed with the other carpet. |
| 08.05.2020 17:46 | # 15 |
tongucuk |
You can get the original matte appearance with black matte spray paint, but this works in the short term. You can pour over time.
| 08.05.2020 17:46 | # 16 |
[QUOTE = ramazanturan81] You can get the original matte look with black matte spray paint, but in the short term, it works well, you can pour over time, the most solid one is to go to a painters or a foil specialist can apply a matte black foil when you want to disassemble it [/ QUOTE] Thanks today, I started with the cif and rim cleaner, on the other hand, I squeezed the polish used for the torpedo, then polished it with a shoe polisher, I rubbed it with a rub for 5 minutes. I must say that I had to wash it with freshness water 2-3 times, except for it, I always wash it by myself. |
| 08.05.2020 17:46 | # 17 |
korkusuz202 |
The medicine you polish the tires works on these black plastic laths and bumpers. |
| 08.05.2020 17:46 | # 18 |
[QUOTE = fearless202] The medicine you polish the tires works on these black plastic laths and bumpers. [/ QUOTE] I thought it was so, hodja, but it matted over time, it hurt, it made me look worse over time, it was worse than the stains made by the freshness of water. |
| 08.05.2020 17:46 | # 19 |
korkusuz202 |
[QUOTE = samet206] [QUOTE = fearless202] The medicine you polish the tires works on these black plastic laths and bumpers. [/ QUOTE] I thought it was so, hodja, but it matted over time, it hurt, it made me look worse over time, it was worse than the stains made by the freshness of water. [/ QUOTE] I do not know how you applied it, but I did not have such a problem.I was washing and rinsing first, then I sprayed the drug on the lath or tampon and spread it with a sponge.I always did this in the shade. |
| 08.05.2020 17:46 | # 20 |
In fact, it gives the necessary brightness if you wipe the old style gauze without any effort;)
