Pogo 206 1.4 xt 2005 multiple temperature
08.05.2020 21:22 # 1
S.AKGUN
When my car goes on the road between 120 and 180, the temperature 70 suddenly ends, the engine says stop, I stop the car, I look at the water, I wait for 15 minutes, then I open the contact, the temperature in the old state, there is a drop of water on the fan radiator carburetor top cover belt sets have changed but somehow I couldn't find a problem with these two. the S.AKG 2019-11-26 07:06:12
08.05.2020 21:22 # 2
[QUOTE = S.AKGUN] When my car goes on the road between 120 and 180, the temperature 70 ends at a time, the engine says stop, I stop the vehicle, I look at the water, I wait for 15 minutes, then I open the contact, the temperature in the old state of the fan, the radiator carburetor top cover belt sets have changed but a I couldn't find any problem with these two [/ QUOTE]
First of all, welcome to us. Check the circulation and thermostat. there may be air in the system. Check the lpg water hoses in one. replace cylinder head gasket i guess. Replace the spare water tank cap in one.
08.05.2020 21:22 # 3
S.AKGUN
Thank you top cover gasket exploded, most of them have changed, let me try it anyway
08.05.2020 21:22 # 4
ilkertan
Hi
I have encountered the same problem these days. My vehicle is 2005 206XT
It was understood that it did not circulate to the service. The engine was turned on, it was understood that the propeller that was circulating was completely disappeared. It has been between 110 degrees.
08.05.2020 21:22 # 5
M.Ahmet059
[QUOTE = ilkert the] hi
[/ QUOTE] circulation pump should change every 60 thousand. Replace the timing belt of these vehicles with the timing belt.
08.05.2020 21:22 # 6
ilkertan
I bought my car from a relative, it has just changed the timing set but when replacing, it was not possible to change the recirculation pump.
