Plumbing Help
08.05.2020 18:15 # 1
oguzhan29
Today, I have my system connected to my vehicle.
Tape: I don't remember the Pioneer mixtrax latest series model
Amplifier: Jameson usa-505 2500 watt 4 channel
Amplifier: Sound magus 600 rms bass amplifier
Speaker: Pioneer 600 watts 100 rms 3 tkm
Bass: Cadence S1 1200 watts 600 rms
Treble: Pioneer Tss 20
Capacitor: Cadence 2.5 farad
Installing my car everything was perfect, but the bass is also good but it doesn't seem like it does not let it go.
08.05.2020 18:15 # 2
barishrocker
I think of kicker from those who give hard bass. I haven't listened to cadence but normally 600rms sub should play well..they may be a problem in the box ..
08.05.2020 18:15 # 3
Alicilik
There are some problems with gain settings. And how many ohms of amp does 600w rms give? Giving 600w rms in 4ohm is a serious job because. It must have a peak power of 5000w.
08.05.2020 18:15 # 4
barishrocker
Sm dk600 2ohm 600rms..If the sub 4ohm 600rms, it may be true that the forehead says. Also, if there is only one RCA in the tape, the power will decrease because the voltage is divided. It would be healthier if you write the exact models and features;)
08.05.2020 18:15 # 5
Alicilik
[QUOTE = barishrocker] Sm dk600 2ohm 600rms..If sub 4ohm 600rms, it may be true that the forehead says. Also, if there is only one RCA in the tape, the power will decrease because the voltage is divided. It is healthier if you write the exact models and features;) [/ QUOTE]
+1
08.05.2020 18:15 # 6
oguzhan29
friends are hitting mad already, letting me inlet, whatever I do, I say it will hurt even more
08.05.2020 18:15 # 7
barishrocker
Cabin dimensions are not made by heart. If you say short but sertols instead of long bass, you can make a closed box. So cancel the port.
08.05.2020 18:15 # 8
oguzhan29
I understand, thanks for informing my brother
08.05.2020 18:15 # 9
barishrocker
You're welcome .. I can't build a cabin, but I have some knowledge. You can make yourself by looking at the booths recommended on the product site.
08.05.2020 18:15 # 10
oguzhan29
ok brother thank you again
