Plug sound from behind in 307 bumps
08.05.2020 20:01 # 1
efeeem307
In the 1.4 comfort end casing-like bumps (although not continuous, especially if the back is full), there is a sound like a plug and play. I took them to the special service, chronic internists would be very hard, he said. If my master was someone with a lie-in la, he would have changed whatever the direct assistant chock moss was. I have full confidence in this. But if anyone has the same problem with me and I find a solution, I would like help ...
08.05.2020 20:01 # 2
pepecura
I have it in my voice.
If you are very uncomfortable with the solution, the astra shock absorber wedges are working.
08.05.2020 20:01 # 3
Bha41
I had the same sounds. There was no sound left, we replaced the rear shock absorbers with those of the monroe brand and fixed the guards to the chocks.
08.05.2020 20:01 # 4
Ozel6521
Of course, I have it in my car, it sounds like the sound will sometimes fade away, Smile
08.05.2020 20:01 # 5
Fanofthepeugeot
Friends have the same subject below, I wrote the solution is very simple, get rid of it.
08.05.2020 20:01 # 6
Fanofthepeugeot
In the meantime, instead of replacing the shock absorber and fixing the bellows, the job would be solved only by fixing the bellows.
08.05.2020 20:01 # 7
efeeem307
brother, for the answer, let me tell the master that I can only hold the bellows. I would also create a problem with the car.
08.05.2020 20:01 # 8
KILIC
teacher you can find hundreds of issues if you search a little. Bellows on the rear shock absorbers fall out. When you enter Cukura etc, those blowers come in and out of the socket and there is a plug sound. Slip down the falling bellows silicones you can do it You don't even need to go to the master or something
08.05.2020 20:01 # 9
Bha41
[QUOTE = Fanofthepeugeot] By the way, instead of replacing the shock absorber and fixing the bellows, the job would be solved only by fixing the bellows [/ QUOTE]
My shock absorbers exploded.
08.05.2020 20:01 # 10
ben_erhan
[QUOTE = KILIÇ] teacher, there are hundreds of them. Bellows on the rear shock absorbers fall out. When you enter Cukura etc, those blowers come in and out of the socket and there is a plug sound. Slip down the falling bellows silicones, you can do it You don't even have to go to the master or something [/ QUOTE]
I just bought 307. I started to search the forum directly. When I saw your message, I immediately applied it. Sounds from the back were silent.
The rear shock absorber sound in peugeot is thus history.
thanks.
08.05.2020 20:01 # 11
ahmettartan
We stick the bellows with cyclone, do I get it wrong?
08.05.2020 20:01 # 12
OguzhanKucuk61
[QUOTE = ahmettartan] We stick the bellows with a cyclone, I understand if it is wrong ... [/ QUOTE]
I understand that too, hodja? Is it true ? I would say this voice too
08.05.2020 20:01 # 13
ben_erhan
Well, for now, I have glued it with fast adhesive. If it falls, I will make a lot of silicone.
The black hollow part there is very light, as it holds with fast glue. Push that piece into the slot above. Give it a try before pasting. There is no such thing as the shock absorber sound coming from behind. This is what happened from the back sounds of the hatcback vehicles.
08.05.2020 20:01 # 14
OguzhanKucuk61
[QUOTE = ben_erhan] Well, for now, I have pasted it with fast glue. If it falls, I will make a lot of silicone.
Thank you for the answer, but I did not understand exactly where. Is it possible to share with you which picture is pasted? oguzhankucuk61 2016-12-23 22:48:24
08.05.2020 20:01 # 15
KILIC
[QUOTE = OguzhanKucuk61] [QUOTE = ben_erhan] Well, for now, I have pasted it with fast glue. If it falls, I will make a lot of silicone.
Thank you for the answer, but I did not understand exactly where. Is it possible to share with you which picture is pasted? [/ QUOTE]
this piece stands upright in the rear shock absorber. Check it out, if it's playing, stick it up
08.05.2020 20:01 # 16
pepecura
how do we see this?
08.05.2020 20:01 # 17
OguzhanKucuk61
Is it possible that this piece will sound so strong ?? I know I saw this on the lift. I think there was a rupture on the right.
08.05.2020 20:01 # 18
KILIC
[QUOTE = pepecura] How do we see this instead? [/ QUOTE]
You can see if the rear wheel looks there. Amartis happens on the problem
08.05.2020 20:01 # 19
KILIC
[QUOTE = OguzhanKucuk61] Is it possible for this piece to sound so strong ?? I know I saw this on the lift. I think there was a rupture on the right. [/ QUOTE]
If it sounds, try it :) it's free :)
08.05.2020 20:01 # 20
ben_erhan
Well, I did not believe that the sound would not be cut, too. But I got into the car and took a tour. What is this?
I can't recognize the car if they close my eyes and get into the car. That piece really made the sound of lacquer.
Page : / 2
