plug-and-play sound when loaded on the gas
08.05.2020 19:41 # 1
akyuz.cagri
Hello friends. As soon as I load the gas, there is a continuous sound coming from the engine in the form of plug and play. It doesn't come when I press the gas when the gear is idle. The sound disappears when I pull my foot lightly from the gas. I can not raise the vehicle over 2500 cycles due to my anxiety. having an idea?
08.05.2020 19:41 # 2
Omer_mydnc
Does the bump have the same sound? Our company vehicle clio had the same problem, when we looked under it, there was a plastic wedge holding the engine at the bottom, fixing the engine, it was broken at that time.
08.05.2020 19:41 # 3
akyuz.cagri
I did not pay attention to the bumps. Let me test it at the first opportunity .. In my general researches, I saw that there may be motor ears, but I am worried about the bed rolling.
08.05.2020 19:41 # 4
Omer_mydnc
I hope the engine is not winding, as you said, if the same sound is heard by pushing the motor back and forth, the engine may not be fixed.
08.05.2020 19:41 # 5
akyuz.cagri
Even if the gear is idle, even if I do 6 thousand revolutions, there is no sound ... so there is no motor movement.
08.05.2020 19:41 # 6
talip206
Your problem is very likely to be the engine mount or the transmission wedge. There are not too many rubber parts but they take a little bit of labor. I recommend you show it as soon as possible
08.05.2020 19:41 # 7
Utkukaraca67
I also showed the master there was the same problem, said injector comes from
08.05.2020 19:41 # 8
ARDADOGAN
engine chock or transmission chock is nothing else
08.05.2020 19:41 # 9
Baver Diyar
Even if the bed is wrapped, he / she will work with a turtled shirt. You can find out if the motor ear is dead or not from the gear night in serial use. When the issue is shifting from 2nd gear to 3, it shakes the engine and knocks the engine.
08.05.2020 19:41 # 10
Utkukaraca67
WHAT DOES GEARBOX DO USE IN THE VEHICLE
08.05.2020 19:41 # 11
AliUmut
If it is loaded into the gas on the go, you need to distinguish well whether the sound coming from the tire or the engine. If it comes from the engine, there may be engine lugs as it is written to friends. you can test it while standing still. open the hood and shake the engine. if you can move the engine, the auricles are gone (it was ridiculous to me until it happened to me)
08.05.2020 19:41 # 12
akyuz.cagri
The right front hood is broken up, whatever is related to the speed rises, the hood begins to rub against the wheel ...
08.05.2020 19:41 # 13
Utkukaraca67
my wheels are rubbing on the hood when I make it right and left. however, the faint sound coming from the engine cannot be from the hood.
08.05.2020 19:41 # 14
Utkukaraca67
HAD I HAVE KNOWED ENGINES OR DO NOT KNOW THE VEHICLES. BUT I CAN SHAKE THE ENGINE FRONT BACK
08.05.2020 19:41 # 15
MadTurk_
If the sound increases as the speed increases, I have that problem. The master gearbox balls have failed, he said. He said either the defective ones or all of them will change as a team. I did not know how accurate it took out a cost like 500-600 lira.
